Data Logging
Data Logging
How do you pull the data logs off the intune? When I open the folder for the logs there are 3 different ones that I had logged but theyre all labeled as 2010. I followed the procedure for the data logging but under the properties it only shows a few seconds of time rather than the minutes that I logged for. Also when I open up the file it is just a bunch of random numbers and letters on the screen. Any help would be appreciated. Reason for the logging is because my car at wot is running super lean and need to check for boost leaks and to adjust my a/f ratio. I have a 2004 neon srt4
Re: Data Logging
browse from dv to the logs folder and click on the file you want to open, and it will open in DV for playback.
Re: Data Logging
dv? when I go to the tuner under data logging and hit play back it says that its currently not supported. this is while its hooked up to the computer.
Re: Data Logging
dataviewer software on the pc, is what you use to play the logs back.
Re: Data Logging
Re: Data Logging
I am using the software in the link and my save log file erros out say invailid data format and the software closes.
2019 Ram Laramie Longhorn 1500 5.7 392 rear ends, new style.
8-Speed
All available options
Unlocked pcm and I3 Diablo Tune
Magnaflow catback system
K&N cold air intake.
8-Speed
Re: Data Logging
is the intune up to date?
post the logs here.
post the logs here.
Re: Data Logging
intue fully updated
- 3GTU2VECXEG265409_00.log
- (3.04 MiB) Downloaded 314 times
8-Speed
8-Speed
Re: Data Logging
post the info file from the tool.
also, try restoring the default pids in the configure menu, then log again and see how that is.
feelinfroggy
Re: Data Logging
Hello,
I'm kinda in the same situation with the data logging.
Trying to get a log for hemifever. After going through the logging process with the in-tune i3, I take it back to the pc and navigate to the device drive. When I open the logs folder there are no newly created logs? What am i missing here? According to Sean from hemifever, thats how I'm suppoed to retrieve the log file to email to him.
Re: Data Logging
The dates on the tool never change. There is no internal clock on the tool to keep track of dates/times. The date is hard-coded in the tool, so the dates won't change, unless an update changes them...
The tune files names do not change, they just get replaced with new copies of the recent tunes you just installed.
And when recording/saving data logs, newest logs have the highest number in the file name.. i.e. _00, _01, _02, _03, etc.. highest number is newest log...
