Hi,
I am have with my InTune DCX unit. I am running Octane 91 tune on my 2014 Sahara Wrangler Automatic transmission. I have modified the tyre size (35") and Gears (4:10) to match what I got.
Is there any other parameters that I need to change. What about gear shift points? How can I modify that?
Thanks for your help.
Do I need any to change any other parameters
Re: Do I need any to change any other parameters
Shift points are not currently adjustable, you shouldn't need more changes.
firefighters_axe
Mikel, Can you clarify this a little more? He needs shift points changed due to re-gearing but unfortunately they are not part of the parameters? Aside from that, he shouldn't need more changes? So, basically anyone who re-gears will not be able to compensate for the change?mikel wrote:Shift points are not currently adjustable, you shouldn't need more changes.
I'll keep using the search button.
Thanks.
the device allows you to program for the new gears to calibrate the speedo, which corrects the shift pattern, no other changes should be required.
