Issue with tune on my 2015 Ecoboost Mustang
just bought the Trinity tuner for my 2015 Ecoboost Mustang. I updated the tuner and installed the 91 octane tune in my car. I have always/only run 91 octane in it. under partial throttle/tip in, it has developed a hesitation/surge.... The only mods I have are an Airraid CAI and deleted the mufflers. Could the mods be causing the issue? Any help would be appreciated.....
Re: Issue with tune on my 2015 Ecoboost Mustang
Im having the exact same issue on my 2015 F150. Im running the Premium tune though.
I refilled my tank and added a bottle of 104+ to it then switched to the premium tune for 91-93 octane. still having the same issue. will try the stock tune tomorrow and see if it helps...... really surprised there is no response on my thread from the company
We're open M-F 9-6...
Some times it takes bit for the post to show up on the forum.
Please post your last tune written and I will adjust it. There's already an update being made for the mustang ecoboost it just hasn't been built yet.
For reference: http://www.diablosport.com/forum/viewto ... 44&t=50990
Insert Clever comment here...
Thank you for responding...
Not sure how to post the tune, it was the most recent one you guys posted in the downloads tab on the main page...
use dsdownloader to export the backup and last tune written and post the files here please.
BACKUP...?
- PCM_SGBN3AA.frg
- (202.08 KiB) Downloaded 534 times
cool, last tune written as well please?
PREMIUM FUEL PERFORMANCE TUNE
- PCM_SGBN3AA_Premium_Fuel_Performance_.frg
- (14.25 KiB) Downloaded 458 times
Actually. Return your car to stock and hit update tool and load this.
Will fix everything and no custom tune required.
- trinity_ford_can_gas-1t13ga_update.crom
- (3.58 MiB) Downloaded 475 times
Will give it a shot. Thanks...
it won't load the update onto the tuner. keeps saying it has encountered a problem and needs to close..
looks like it finally downloaded. connected to car and chose custom tune instead of diablo tune...is that correct?
No, if you loaded the update, just use the Diablo tune.
Ok.. I have tried both the custom tune and the diablo tune after updating the trinity. The custom tune seems to have cured part of the issue, but not all. Loaded in the diablo tune and it is worse. Air fuel ratio is pegging at 20 and vacuum stays around 23 on decel/downshifting with paddles... very pronounced stumble still at tip in/partial throttle... runs ok at higher rpm, but light throttle not so much... any info?
