No cruise control
DarrylMan
No cruise control
Post by DarrylMan »
Hello all, I recently had my predator U7180 upgraded, by recently i mean got it back yesterday. I have a 2001 Sliverado 2500hd, 6.6l LB7 , allison 1000 automatic trans. As stated in the subject, when I write any of the custom tunes provided with the predator, my cruise control no longer functions, if I restore original, cruise works fine. Whats up with that? Another issue I notice, your formula for tire size compensation needs some work. I set tire size 265/75/16 same as I did before tool update, now speedometer out (slow) by 20 kms so now I have to start experimenting with different tire sizes, begining to wonder what other bugs are in there. :(
DarrylMan
Re: No cruise control
Post by DarrylMan »
Hello, is there anybody out there.....
I havent seen any cruise issues, but if the speedo is adjusting wrong, that could be the issue.
DarrylMan
Post by DarrylMan »
well I got speedo calibrated, had to use 271/75/16, but still no cruise on any of the supplied tunes.
DarrylMan
Post by DarrylMan »
So you guys fixing this stuff or what? very poor customer service, maybe a call to my cc and charge back will get your attention.
Please use the dsdownloader to export the backup and last tune written fromthe tool and post them here and we'll take a look at the files.
DarrylMan
Post by DarrylMan »
Last tune written is original stock, is that the one you want to see?
No, I would need you to load the tune that leads to the issue then export the files so we can see them please.
DarrylMan
Post by DarrylMan »
ok, here is the 85 Hp tune as written to the truck.
DM15188873C1A_custom.grd
85 Hp tune
(2.25 KiB) Downloaded 737 times
please export and post the backup as well.
DarrylMan
Post by DarrylMan »
original back up attached
dm15188873c1a.grd
original backup
(154.82 KiB) Downloaded 796 times
DarrylMan
Post by DarrylMan »
So.......how we doing with this issue?
there were no changes outside the tunes that would seem to cause an issue, we're taking the files apart to investigate but it takes time, sorry for the delay.
DarrylMan
Post by DarrylMan »
Ok, just an FYI, the tunes from the old version 1.11 all worked fine with my truck, cruise worked with all of them.
Yeah, thats the trick, as nothing has changed from all the way back then, so its not jumping out at us at all.
