Hi guys , i have a 2013 dodge challenger 426 stroker, with magnuson tvs supercharger with 12 LB psi boost.
Is there a guide or easy way to setup wideband 02 sensor on my trinity and to my car ?
wideband 02 sensor on Trinity
Re: wideband 02 sensor on Trinity
http://www.lxforums.com/board/showthrea ... atalogging
that should help
LMK if you need the two channel Male plug with 6' lead (last item listed on first port) , I bought like ten of em.....I could mail you one cheap
the directiona are little off on the ay you set up to add the gauge to the trinity, as I remember.
when you go to add the gauge to the preselcted PIDS list, it wont go, the icon wont fit, but trinity doesnt tell you , it just tries to kick other icons off of the page. SO B4 you add your new gauge...add a new PAGE so it has room for it.
ALso find your scale for your AFR so when you get to scailng the gauge( which is diffenrt then adding the 0-5v range.....) you know what numbers to put it. In my case the zetronics...the scale indicated inthe tutorial ( I think its there) is wrong, the sale was in my old instructions, a grid box with aline and the scale was in SMALL print)
Happy motoring
that should help
Happy motoring
keeganjacobs1122 wrote:Hi guys , i have a 2013 dodge challenger 426 stroker, with magnuson tvs supercharger with 12 LB psi boost.
I sent you a PM
thanks
