Still can't disable Traction Control ...
Brian13RT
Post by Brian13RT »
I still can't disable my Traction Control via the Quick Adjust menu on my Intune DCX. I've read where this is also happening to others as well.
Is there a fix for this yet?
hellrose1228
Re: Still can't disable Traction Control ...
Post by hellrose1228 »
Same here.I have a brand new 2014 charger SXT plus 3.6/8spd. I get the "traction control failed to update" code every time.
Playhard
Post by Playhard »
Not sure of this applies but on my 11 rt it only disables it for one run then resets once I turn the car off. It has to be repeated again and again with each restart of the engine. So its really only good for track day runs. To much work otherwise. Not sure if that's changed now with all the updates but I suspect not.
hellrose1228
Brian13RT wrote:I still can't disable my Traction Control via the Quick Adjust menu on my Intune DCX. I've read where this is also happening to others as well.
https://www.diablosport.com/forum/viewt ... 57&t=48802
