srt8 failed to update tire size
07 charger srt8 , iam unable to adjust tire size. when i input the tire size and ready to load it i get " failed to update tire size" . version 1r13c serial 6QE894C-4
Re: srt8 failed to update tire size
ANYBODY HOME
does it say that after you make the adjustment and do the key cycle?
its usually working when this happens, you can confirm by changing the height in inches setting then go back and see if it shows the value you changed it to.
mikel wrote:does it say that after you make the adjustment and do the key cycle?
I dont even get that far, it will ask me if iam sure and then click yes.. after that is when it tells me "failed to update tire size".
any info for over this matter?
Hi.
I have exactly the same issue with my Dodge Durango 2009.
I was hoping for a change now when updating my Trinity but stillthe same
I am also having this issue on my 2007 Dodge Charger SRT8 and haven't heard back on it. Any update on this issue?
