Dataviewer not reading datalog
CHRCHX
Post by CHRCHX »
Hello, i want to do some data logging on my vehicle since it through a P0190 Code. My intune is up to date so i followed the procedure to data log. plugged it into my pc. downloaded dataviewer 3.3.0.17. Copied the log onto my pc. then when i open it in dataviewer I get the following error:
Critical Failure
Log File Error
Log File was an invalid format
Do you know why this is?
I added the log file if that helps.
Please Help, Chuck
1FAFP45X5YF205850_00.log
(242.02 KiB) Downloaded 110 times
Re: Dataviewer not reading datalog
on the intune select restore default pids under configure in the logging menu then try a new log.
CHRCHX
Post by CHRCHX »
Thanks Mikel. Worked just fine.
