Intune burned in a fire. What are my options
My intune burned in a housefire,but the truck is still tuned. Can i get a replacement that Will work with the installed tune.
2014 Chevy Silverado 6.2L LTZ- Max Trailer Package / Air Raid CAI /shorties/Ported TB/ Diablo Intune/ NOS 45 shot/ Tonno Pro Tri Fold
Re: Intune burned in a fire. What are my options
a replacement will allow us to get it all back to stock generally, what vehicle is it specifically?
Its a 2014 Silverado LTZ 6.2L
do you by chance have copies of the backups from the old tool?
Sadly, i lost the laptop. I do have the programmer, but the case is melted. Is it possible to retrieve anything from that?
plug it into usb and see if there are files on the drive.
When i get home, ill see if i can find a cae that will work. That was butned up. The port looks a little disfigured, but ill see how it goes and let you know.
I was able to recover intune files from the burned laptop, but I can't tell what is what. Would it do any good to send you any of these. Some may be from my old 2010 6.2L
Update: I found a usb cable that had a matching plug. Plugged it in, but the pc didn't pick up the USB. The screen comes on white. Have no idea if it is booting when i do this.
sounds like the tool is not functioning, and will be impossible to retrieve files off of it.
What are my options? Can a new unit be set up to work on my truck? Someone should have a stock file that could be used as a stock base.
Attached is a clip some files I found from the hard drive on the burned laptop.
- Intune files found
- Capture.PNG (30.45 KiB) Viewed 3212 times
the unit powers on, but there is no screen.
- power no screen
- IMG_2507.JPG (90.55 KiB) Viewed 3211 times
