3.3.0.09 through 3.3.0.16 Crashing
duster360
Post by duster360 »
Ever since 3.3.09 came out and all the way through 3.3.0.16, more often than not, it crashes when opening a new log.
On 3 different PCs running Windows 7 and now 10, if I already have a log open and then try to open another, Dataview locks up.
The lock up occurs nearly every time if I say YES if I want to save changes to the current log before opening the new one.
Any ideas?
I've been using 3.3.0.8 for years now with no issue whatsoever. With every new version, I think the issue maybe fixed but to no avail.
DataViewer Locked up.JPG (33.18 KiB) Viewed 19422 times
Needless Torque Calibrations
www.needlesstorque.com
garrett
Site Admin
Re: 3.3.0.09 through 3.3.0.16 Crashing
Post by garrett »
try uninstalling Dataviewer, then run a disk clean in the program files to wipe any temporary files that may be stored. reboot then try reinstalling the latest version. http://www.diablosport.com/CMR/software ... 3.0.17.exe
duster360
Post by duster360 »
Thanks Garrett, ill try that
duster360
Post by duster360 »
garrett wrote:try uninstalling Dataviewer, then run a disk clean in the program files to wipe any temporary files that may be stored. reboot then try reinstalling the latest version. http://www.diablosport.com/CMR/software ... 3.0.17.exe
Same issue. The initial log will open 100% of the time but if a new a log is then selected to open, DV can crash. It is more likely to crash if you answer YES to save the current log.
It also seems to be more likely to occur with InTune logs if that's even noteworthy.
Again, 3.3.0.8 has never had this issue but every DV since 3.3.0.9 has.
Problem signature:
Problem Event Name: APPCRASH
Application Name: DataViewer.exe
Application Version: 3.3.0.17
Application Timestamp: 55c8cad2
Fault Module Name: ntdll.dll
Fault Module Version: 6.1.7601.18798
Fault Module Timestamp: 5507b3e0
Exception Code: c015000f
Exception Offset: 000848b1
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
DiabloMatt
Post by DiabloMatt »
wanted to update you. i forwarded it our windows guy and he is looking into it.
duster360
Post by duster360 »
DiabloMatt wrote:wanted to update you. i forwarded it our windows guy and he is looking into it.
Thank you
duster360
Post by duster360 »
Any update?
Is there anything I can do to help resolve this issue?
I dont have any further input, but man, I have never seen this reported by anyone else...could it be something on your PC?
The 3.3.0.11-latest have been so much more stable than past versions, it just seems like opposite day with your PC.
Have you had a chance to try one on another PC by chance?
duster360
Post by duster360 »
mikel wrote:I dont have any further input, but man, I have never seen this reported by anyone else...could it be something on your PC?
I would like to think so but the issue occurs consistently on 3 different pcs, one at work and two different laptops at home.
I thought the new CMR laptop I got a few months ago would have the best chance since it was clean. IIRC version 12 was out at the time but nope, it'd still crashed when saving the current log and lock up in the middle of trying to open a new log.
Several customers have reported the same issue. So I keep a copy of 3.3.0.08 on my Google drive to hand out when needed. Again, for whatever reason .08 has never had an issue.
DiabloMatt
have you tried 3.3.0.17? maybe have more luck with it?
duster360
Post by duster360 »
Again, it seems less likely to occur if i don't let DV save the current Log before opening the new Log.
Could the mechanism the remembers what PIDs were checked off while the log was open, be the source of the crash?
duster360
Post by duster360 »
DiabloMatt wrote:have you tried 3.3.0.17? maybe have more luck with it?
yes absolutely just as you had instructed the other day
DiabloMatt
man i have no clue. i use this thing every day as do tons of other people. our windows guy is out for the day but i'll ask him.
duster360
Post by duster360 »
DiabloMatt wrote:man i have no clue. i use this thing every day as do tons of other people. our windows guy is out for the day but i'll ask him.
I use it everyday on two different PCs and periodically on a 3rd. Here you go, it took me just a half dozen saves & open for 3.3.0.17 to crash just like all the others version sans .08.
It's hard to believe I'm the only one.
DV 3.3.0.017 crash.JPG (91.7 KiB) Viewed 19265 times
duster360
Post by duster360 »
Do me a favor, and cycle between these logs and see if it locks up. Check off a different PID each time and select YES when asked to save it.
It seems to be consistently crashing while saving/opening either of the "Lean 1025cc BWS3" logs.
CGardiner IDLE AFR 14.2-15.2.log
(242.17 KiB) Downloaded 808 times
1B3ES66S14D501426_06.log
(116.58 KiB) Downloaded 856 times
Lean 1025cc BWS3 1B3ES66S95D148645_03.log
(1.09 MiB) Downloaded 800 times
Lean 1025cc BWS3 1B3ES66S95D148645_02.log
(1.23 MiB) Downloaded 998 times
Return to “DataViewer/DV2”
