160 degree stat
NYESCALADE
160 degree stat
I was told that a low-temp stat would really help my truck by keeping it cooler of course, but I can't find ANY for Escalades, any ideas guys? And is it really true?
2005 GM
U7193, Software 2.10, Hardware 1.10
CAI
Dual 3" Electronic Exhaust cut-outs
CAI
RE: 160 degree stat
naaah....
here, check this out...
I've talked with GM techs, and they say that these cars like to run a little warmer to perform the best... and to not use a 160* t-stat which will stay open all the time and not actually allow the coolant to "cool off" to actually cool the engine...
here's some additional info I have:
What effect the 160 stat has on the engine/computer depends on different factors. In terms of achieving closed loop operation, the oxygen sensor plays a more important role - it will not function until the exhaust temperature is at least 660 degrees F. To a degree this is a function of the coolant temp, so it is possible that abnormally cold coolant temps can prevent closed loop operation.
If the coolant reaches 160 degrees, there should be no problem, as the torque converter lockup AIR, and EGR function at temps over (approximately) 150 degrees F. The trouble is that overcooling (and subsequent chronic open loop operation) is much more likely with the colder stat, since you are running that much closer to the "crossover" temp. This is especially true in colder climates, where the ambient temperature can contribute to the overcooling problem. A 160 stat is probably not a good idea if the ambient temperature is below 75 degrees F, or if a significant percentage of the driving time is spent on the highway. In that case, go with the 180 instead.
Aside from loss of converter lockup, AIR, and EGR operation, overcooling can cause an abnormally rich air/fuel ratio, which at best will make your fuel economy and performance suffer, and at worst will destroy the catalytic converter. In any case, the colder stat is not much good without changing the temperature at which the radiator fan activates. During city driving, the fan will simply wait until the coolant reaches 225 degrees F to turn on, which is what you were trying to avoid in the first place.
there is a "middle ground" where both optimum performance as well as minimal wear share similar characteristics. That "magic" number lies in the 175-180 degree range, which requires a 180 degree thermostat..
The all too commonly used 160 degree thermostat is way too low to be considered for performance or engine longevity. As the chart illustrates, engine wear increased by double at 160, than at 185 degrees. So then, why do the 160's exist in the first place? The 160's were commonly used in older, open loop cooling systems where only 6 pound radiator caps were used, and low 212 degree boiling points were experienced. In contrast, modern cooling systems can see upwards of 260 degrees in coolant temperature with radiator pressures exceeding 45 pounds. Many early hot rodders found the 160's to be better performing than the 190's, however, the in between "180" appears to satisfy both ends of the spectrum. The correct water temperature is required for the cylinders to achieve a minimum specific temperature in order to allow a fully homogenized Air/Fuel mixture to combust efficiently. Guess what the minimum number is… right! 180 degrees. Even so, you might see some still recommending the lower 160's, for no other reason than to possibly get that last drop of horsepower out, at the high price of dramatically reducing the life of the engine and it's internal components.
RE: 160 degree stat
With a 160 t-stat my truck runs at 176.
2004 4.8L Silverado RCSB
-Custom CAI, 2" - 5" drop
-Flow 40 series 3" in dual 2.5" outs w/ turn downs
-Custom e-fan setup
-All synthetic
-Diablo tune
-160 t-stat
-Doug Thorley Headers.
http://www.myspace.com/dodgesucksfuckingass
-Custom e-fan setup
-All synthetic
-Diablo tune
-160 t-stat
sickREDsierra
RE: 160 degree stat
i used to pull my thermostat in my old s-10 in the summer time. it ran around 150 when i did that.
2007 Sierra, 370 C.I. , Custom CompCam, ProEdge 3600 converter, 4.11's with eaton LSD, Foose 20's, DynoTune Nitrous, Patriot CNC'd heads
sickREDsierra
Re: RE: 160 degree stat
S10HotRod wrote:With a 160 t-stat my truck runs at 176.
whats your truck look like/ride like with the 2" drop shackles? i was thinking of doing that.
NYESCALADE
RE: Re: RE: 160 degree stat
So I guess I'll leave the factory stat.
SickREDsierra - I have the factory suspension, no drop.
2005 GM
CAI
CAI
It rides the same as stock with less rear roll. It had a very high rake. Another 1" it would be even. I need to start saving for the 2" spindles and the 2" hangers.sickREDsierra wrote:S10HotRod wrote:With a 160 t-stat my truck runs at 176.
I had a 1988 s-10 that I took the t-stat out also.Those were the days. I put a cam, performance TB, took the power steering and AC out, pacesetter full lenght headers, and some other stuff. The quickest time I got the 2.8L V6 down to was a 17.1 at the 1/4 mile at like ~85 mph. How awesome is that!
- Truck.jpg (53.46 KiB) Viewed 1858 times
-Custom e-fan setup
-All synthetic
-Diablo tune
-160 t-stat
-Custom e-fan setup
-All synthetic
-Diablo tune
-160 t-stat
