9r01 revision
johan
9r01 revision
Post by johan »
I just put the new 9r01 revision up for you guys.
Issues addressed:
*Key counter reset
*Speed limiter adjustment
*Attempt to fix idle surge in 35xxxx calids.
http://www.diablosport.com/downloads/pr ... -9r01.crom
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
03dodgeoffroad
RE: 9r01 revision
Post by 03dodgeoffroad »
so this is for the 7131 and not my 7130 for my 03 when is that one going to be done
RE: 9r01 revision
The U7130 is being addressed very soon.
Cookiemanster
Well I'll be........
Post by Cookiemanster »
Just loaded it in my 06, loaded first try and idle up as well as tire size worked on the first go, nicely done. :lol:
Anybody know of any 35" load range D or E tires that are "Z" rated for use above 149MPH, it seems we now have the door open all the way up to 155MPH :shock:
The quick adjust feature is nice too, tried it out and it works well.
Did you guys alter any of the performance side of the tunes at all?
dclevey
RE: Well I
Post by dclevey »
Cookie, What is the quick adjust?
President of C.O.P.A.D.S.
06' Cummins. 5'' Turbo back, DS+Puck, Edge Insight,Quad Boost Fooler, DCL Intake, MIA: Kitty, silencer Ring, tube guts and self control!!
RRAM
RE: Well I
Post by RRAM »
Glad to hear about the 7130, I hated to complain but its so bad when it idlos up on its own. Its not only embarassing, I can't imagine it is doing well for the engine. If I go and turn on the manual high idle it jumps to 1100 and is much smoother. I think my cal is 25xxxxx. I have it on perf tune.
Reg
2005 3500 Quad Cab Laramie L/B
Predator, AFE stage II, boost fooler
Pillar Mount gauges Billet low stall TC
Cookiemanster
Re: RE: Well I
dclevey wrote:Cookie, What is the quick adjust?
Well let me tell you...................Quick adjust lets you turn the idle up feature on/off and adjust the tire size without having to load the entire tune again, kinda' like shift on the fly for some of the features.
I can't believe that with all the bitching about the Predator that I'm the only one who posted the latest info.......WTF? :roll: I thought for sure there'd be at least a thousand downloads and reports on it by now!
dclevey
RE: Re: RE: Well I
Post by dclevey »
Dang!!! I thought it my be a power level quick adjust!! Oh well, we appriciate the attention given to the other issues. Thanks!!
hasman70
Post by hasman70 »
mine is cal id 35325853ae, will this update work on my 06? THANKS A BUNCH FOR GETTING BACK TO US IN THE DIESEL CROWD!
Will work on any 06-07.
mmm...diesel
FRIED???
Post by mmm...diesel »
Mike/Johan,
I connected the predator to my computer to write the new revision that you have. Everything worked great, it downloaded fine and said it was successful. I unplugged the predator from the computer and the power supply like the instructions said, took it out to the truck, and it doesn't boot up, it just gives a blank screen. I brought it back in and tried to reload the new file, but when i plug it in it still just gives a blank screen, and the computer never recognizes it.
Whats going on here??? This just adds to my disappointment with your product. Not only have I spent hard earned money on something that didn't work correctly in the first place, I now have a three hundred dollar plastic paperweight. What gives???
2006 Patriot Blue 4x4 6spd QC SWB Edge Juice W/Attitude, boost foolin, k&n replacement filter, 36" Magnaflow (trade for Donaldson), Predator stacked w/edge, puck in box
Herculou
RE: FRIED???
Post by Herculou »
I wanted to wait a few days to make sure the tune was good on the 9r. I'm happy to say it works great.
And I think I'm getting better MPG as well. Will have to check it more on the next fill up...
06 CTD, AFE, 6 speed 3.73, predator
elkyluvr
tune on the fly
Post by elkyluvr »
i have an 07 six speed. i have r14 now. i have never had a surge or rough idle problem. can you give me the new revision with the same old tune on the fly. i am only asking because of the key count issue. thanks.
dclevey
RE: tune on the fly
Post by dclevey »
I would like that too, if possible.
hasman70
Post by hasman70 »
I've installed 9r01 revision, haven't ck'd the key counts issue yet, my overhead mpg has been slowly climbing up but I haven't ck'd to see if it is real or not. Idle surge at high idle is still there, doesn't seem to be as bad as it was before, but still there. Happy with the revision other than that the high lift cam idle is hangin around.
