2015 Eco Boost Dead peddle Info Thread.
DiabloMatt
Re: 2015 Eco Boost Dead peddle Info Thread.
anyone else want to try?
I would man but I have to wait for the wife to come home with the truck.
Sorry that should have read Matt.
Got mine programmed and everything working good so far!
DiabloMatt
juice055 wrote:Got mine out in and everything working good so far!
Matt, I'm out of town this week till Friday and my truck is sitting at the Atlanta airport. I'll post up tunes when I get back in town and have access to my truck!
Hello , 15 f150 3.5 eco boost XLT sport pkg
Can i please get the instructions, how to get my back up file so i can post it ?
Thank you.
Thank you.
I have a 2011 F150 EcoBoost, I just got my i2 last week and I am getting the Dead Peddle....
So I have used my truck extensively since uploading the tune and NO dead pedal!!
Last night I used my truck to haul about 5 loads of garden waste this involved around 5 key cycles some off roading (maybe a few donuts).
I used 4wd Auto, 4wd High, and normal driving. No dead pedal.
Did not use 4wd Low or tow/haul mode
Sport mode works the same as before holds the RPM higher etc just with more power!!!!!
Good work guys!!!
Other people be patient the full build will be here ASAP, just think how happy the guys who were working on this would be to have it resolved. I personally cannot wait for the 93 octane update.
Good work guys!!!
DiabloMatt
mvtharley wrote:I have a 2011 F150 EcoBoost, I just got my i2 last week and I am getting the Dead Peddle....
did you use the quick adjust to change gear or tire size? if so this has been fixed. return the truck to stock and run the updater program on the tool and try again
plug tool into truck. load any tune you want. doesnt matter. then plug tool into your computer. once it connects. go to the I2 drive (just like a thumb drive) and go to the "tunes folder" attach the "origianal back up" hereeuro* wrote:Hello , 15 f150 3.5 eco boost XLT sport pkg
Thank you.
adamtrop wrote:So I have used my truck extensively since uploading the tune and NO dead pedal!!
Good work guys!!!
i'll post up a 93 for you in a min...
DiabloMatt
adam: 93 tune on the rocks.
- test 93 adam.frg
- (145.58 KiB) Downloaded 311 times
DiabloMatt wrote:adam: 93 tune on the rocks.
Adam, the 93 tune is nasty!!!
Since loading 87 test tune I have 3 heat cycles, 8 key starts , 165 miles , and a very happy right foot.
This is all good!!
This is all good!!
I hope this is right
- PCM_PKCMAW6_Backup.frg
- (165.67 KiB) Downloaded 361 times
DiabloMatt
[email protected] wrote:I hope this is right
one 87 tune and one 93 tune... both with a hint of lime
- test 93 drc.frg
- (145.56 KiB) Downloaded 311 times
- test 87 drc.frg
- (145.65 KiB) Downloaded 273 times
