2015 Eco Boost Dead peddle Info Thread.
Re: 2015 Eco Boost Dead peddle Info Thread.
Matt Do I copy it to the tunes folder?
DiabloMatt
[email protected] wrote:Matt Do I copy it to the tunes folder?
no you copy to the main i2 drive. (or intune drive) NOT any of the sub folders. if using a i2. click continue on the screen after it says the tune has been loaded.
ok I put them in the i2 folder but the tool does not give me the option to tune or load. only option is settings . updater says no updates thanks for the help btw
Here mike Do Magic and stuff
- PCM_PKCMAW3_Backup.frg
- (166.31 KiB) Downloaded 313 times
ok got it I'll let you know if it works
Loaded updated 87 tune twice still no pedal put stock tune back in.
DiabloMatt
post up the last tune written please.[email protected] wrote:Loaded updated 87 tune twice still no pedal put stock tune back in.
its in the "tunes folder"
DiabloMatt
halflife 87 and 93 tunes salt on the rim
- test 93 halflife.frg
- (146.48 KiB) Downloaded 254 times
- test 87 halflife.frg
- (146.36 KiB) Downloaded 261 times
tunes folder is empty
DiabloMatt
[email protected] wrote:tunes folder is empty
oh i missed that you put it back to stock.
sorry.
please make sure you are going to "advanced tune". then clicking "custom tune" and selecting the "test 87 tune" load it back into the truck and if its still dead. post the last tune written please.
ok It worked have pedal now going for a drive to check it out The i2 loads way faster then the itune
DiabloMatt
[email protected] wrote:ok It worked have pedal now going for a drive to check it out The i2 loads way faster then the itune
yes the i2 is a bad bitch for sure....
Well I now have throttle and seems to work good. I'll put some more miles on to make sure but so far it's good
DiabloMatt
alright guys. the fixes are done over here. once they are built a update will be released within the next few days. and then i say all you guys fly in for a party!!!
Need Some Magic over here
- PCM_PKCMAK4_Backup.frg
- (165.67 KiB) Downloaded 219 times
