2015 Eco Boost Dead peddle Info Thread.
Re: 2015 Eco Boost Dead peddle Info Thread.
Matt,
Any chance I could get a custom tune as well? My backup and last tune written are posted on the previous page.
Make that page 18.
Make that page 18.
DiabloMatt
Scheibel wrote:Matt,
Make that page 18.
here you go. sorry about that
- custom_91_performance_.frg
- (144.97 KiB) Downloaded 264 times
DiabloMatt wrote:Scheibel wrote:Matt,
Make that page 18.
Thanks Matt! I'll try it out after work.
Matt, got the tune you posted to me loaded in the truck and everything seems to be fine. Shut it off and on a few times, then drove it 10 miles or so, then shut it off and on again, and no dead pedal. Definitely is more responsive and has more power. I'll let you know how it does.
In my case, I didn't loose the pedal immediately, but after a day or two. Bryan sent me some tunes to try, and the last one I tried, it never lost pedal completely, but would loose power when taking off from a stop or even on cruise control riding down the interstate. Would just either loose power while cruising or when taking off from a stop acted like it was half power. Had to floor the pedal to get it to start acting right. After that, I restored to stock and waited till today when you sent me the tune to try. I'll let you know how things progress.
DiabloMatt
garden98 wrote:Matt, got the tune you posted to me loaded in the truck and everything seems to be fine. Shut it off and on a few times, then drove it 10 miles or so, then shut it off and on again, and no dead pedal. Definitely is more responsive and has more power. I'll let you know how it does.
did you load the latest update i posted? if so i think it might be breaking the custom tune. we are working on another update as we speak
also if you can, flash that custom tune and then post up the last tune written. i need to see what the tool is doing
Matt,
Yes, the file I loaded was the custom file you provided, not the update. When I saw that the update was having problems right out of the gate, I asked and you told me not to load it you. You instead provided me with a custom tune. That is the one that I loaded and is doing fine. Here is the backup (downloaded from the truck that was updated by Ford 2 weeks ago), and the last tune written (the custom tune you provided today).
- PCM_PKCMAG2_LastTuneWritten.frg
- (165.5 KiB) Downloaded 279 times
- PCM_PKCMAG2_Backup.frg
- (166.08 KiB) Downloaded 297 times
DiabloMatt
im so sorry...i misread you... it DOES work..
i read that is NO PEDAL...lol
DiabloMatt
guy that have SUCSESSFUL custom tunes.... can you post up your last tune written please. and thank you
Here Matt.
I have been using mine for about a week now and it has been going strong. No issues.
- PCM_PKCMAW3_LastTuneWritten.frg
- (165.9 KiB) Downloaded 297 times
juangorena
i´ll try it from today 11/18/15 keep you posted
Hey Matt,
I tried the 91 octane tune you made for me after work today and had no luck. It could be due to the fact that my backup was created last week after you released the new CROM and I since unmarried my tool to go to the dealership on Monday. I had to remarry it before I could install the custom tune you wrote for me today. I'm not sure if that new backup created differs from the old backup and is creating the problem.
It also might be worth noting that since I've had the tool I've never had any trouble running the modify stock tune.
For reference I'm going to attach my old backup, the off the shelf 91 tune that failed, the 91 custom tune you wrote for me, as well as my new backup and the modify stock tune that is working with no dead peddle. Hopefully there will be some info in there that will help.
Also, if you could send another custom tune my way (either 87 or 91) I can give that another try; would love to get something working.
Scott
Scott
- PCM_PKCMAK5_Modify_Stock_Tune.frg
- (1.25 KiB) Downloaded 244 times
- PCM_PKCMAK5.frg
- (193.35 KiB) Downloaded 276 times
- (144.97 KiB) Downloaded 316 times
- PCM_PKCMAK5_91_Performance_OFF_THE_SHELF_OLD.frg
- (9.25 KiB) Downloaded 284 times
- PCM_PKCMAK5_OLD.frg
- (193.35 KiB) Downloaded 256 times
Hey. Sorry about the delay. Broke my foot start of October and due to some complications I've been in hospital and bedrest. Soon as I'm mobile again I will load that tune and give it a try for you.
Matt,
here is my 87 test tune, going on 11 days, 975 miles and no issues. You could make me a 91 test tune to try.
- PCM_PKCMAH2_LastTuneWritten.frg
- (165.46 KiB) Downloaded 225 times
Mind if I get a custom tune too? Or a test tune to try? I downloaded the latest update, put in in the truck and immediately had the dead peddle.
- PCM_PKCMAW2_Premium_Fuel_Performance_.frg
- (9.25 KiB) Downloaded 224 times
- PCM_PKCMAW2.frg
- (193.36 KiB) Downloaded 249 times
hi matt can you also send me a custom tune for my truck i also get the dead pedal right away like 3 or 4 miles after i install it
