Custom Tune not being recognized
xPosTech
Re: Custom Tune not being recognized
Post by xPosTech »
IrishNation24 wrote:
Davidryan1987 wrote:I am starting to think I might send this i2 back to Amazon and get the old version. If I am correct the old model will recognize the custom trans tune? Can anyone confirm that?
Yes it can, but the price on those if you can even find one for sale is gonna be sky high I would imagine. Those are much easier to use to. And from what I understand, you can actually see all the tunes you have loaded onto it, and delete them if you want. Can't do that on the new one.
Why would the price be sky high? Amazon had the I1000 about $25 less than the I2030 when I bought it.
I'm finding more bugs with the forum s/w than the inTune.
Ted
2010 Silverado 5.3 Extended Cab 6.5' Bed 6L80E Flex 3.42 Z85 Tow Mirrors Airaid MIT
Firestone Ride-Rite Pirelli Scorpion ATR Diablo InTune 2030 Wheel to Wheel Polished Stainless Steps
18% Front 20% Side & Back AVS Smoke RainGuards & BugShield Weathertech Mud Flaps
and amazon.com is not an authorized dealer either.. so no warranty on the product if bought from anywhere on there..
OK< the fix is in, sorry it wasnt earlier as promised, but I took some extra time testing it.
Save both attached files to the i2 drive, let the tool import them, then go to the vehicle and you can load the custom tunes.
Select the pcm custom tune (or skip this module if its already loaded) then select install custom tune again and it will present your TCM tune, worked for me on our 14 Sierra ;)
kerrslight
Post by kerrslight »
Thanks Mike. I'll give it a shot.
gorman71
Post by gorman71 »
works great! Thanks! :D
2014 Silverado LT Double Cab Z71-Airaid Intake, Gibson Exhaust, Diablew Tune
Davidryan1987
Post by Davidryan1987 »
Did Not Work On My 2015 Model After The Update Just Now.
Any Other Ideas?
Davidryan1987
gorman71 wrote:works great! Thanks! :D
Did You Have To Do Anything Special Besides Update The I2?
What Year Is Your Truck?
kerrslight
Davidryan1987 wrote:Did Not Work On My 2015 Model After The Update Just Now.
Any Other Ideas?
Did you download the attachments mike attached? Also, did you update your device?
kerrslight
In Mike's post, there are two files you have to download and then drag to your device. Your device will update the files and reboot. My guess is if you do that and run the updater, it should work fine.
willyr1er
Post by willyr1er »
Works!
Any Other Ideas?
please post your current info.xml file from the i2 drive so I can see if the updates loaded, but it seems you didnt get them loaded ;)
Davidryan1987
Any Other Ideas?
<tool_info>
<registration sn='14U7Z5M30W' status='0' tool_oem='DIABLO_G' updates='0'/>
<applications count='5'>
<application name='vehicle' rev='2r01b'/>
<application name='updater' rev='missing'/>
<application name='gui' rev='2t01ba'/>
<application name='installer' rev='2r01a'/>
<application name='logger' rev='2r01a'/>
</applications>
<databases dbnames='2r00' dtc='2r01a' vin='2r01fa' gui='2t01ba'>
<database mfr='DCX' pid='2r01cc'/>
<database mfr='FORD' pid='2r01cf'/>
<database mfr='GM' tune='2r02q' pid='2r01ba'/>
</databases>
<last-connected vin='3GCUKREC7FG189608' mfr='GM' calid='12664769, 12664266, 12665174, 12653630, 12659034, 12659078, 12659919, 12664527'/>
<last-connected calid='24270599, 24271221, 24274447, 24271222'/>
<licenses available='1' tuned='1'>
<license vin='3GCUKREC7FG189608' mfr='GM' ECM='12665174' TCM='24274447'/>
</licenses>
<reg reg='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'/>
</tool_info>
Davidryan1987
I Have Tried Multiple Different Times Multiple Different Ways. Below Are The Different Ways I Have Tried.
I Tried Just Doing The Update Then Going To The Truck And Nothing It Still Only Sees The Ecm Tune.
I Tried Downloading The 2 Files That Where Provided And Doing The Update Then Going To The Truck And Nothing It Still Only Sees The Ecm Tune.
I Tried Downloading The 2 Files That Where Provided And Not Doing The Update Then Going To The Truck And Nothing It Still Only Sees The Ecm Tune.
Has Anyone Tried This On A 2015?
Davidryan1987
Attached Is The Info File That Was With The 2 Files Loaded And Then The Update
you do not have either file loaded.
Save the 2 files to your pc.
copy both of them, and paste them to the root of the i2 drive.
let the tool import the 2 files, it will display on the screen what it is doing, then you can go to the truck and the TCM tunes will show up.
