I have a 08 Dodge SRT4 Caliber that I bought recently and a Intune from my previous SRT Neon that I sold. I decided to use the Intune as a scan tool for the time being since I don't have a wide band installed yet. Just wanted to look at the default PIDS on the logging option. The standard outputs look normal except that ST knock of 96 deg. It just shows that value all the time. Thought that was odd but maybe cause I haven't installed a DS tune yet. Then I saw a individual on SRTcaliber forums post questions about the same values with his Intune. So I thought I would ask here as to what that value represents.
Tom
ST knock 96 deg?
Re: ST knock 96 deg?
can you record a log then post it here?
Will the intune store a log if it is not married to the vehicle?mikel wrote:can you record a log then post it here?
Tom
mmmmm seems odd. MAke sure the tool is fully updated and then once you're done with all that go to scan tool - datalogging - configure - restore default pids
Then try again. Should be good then. Caliber uses a set of pids that are unique to it so shouldn't have this issue.
Insert Clever comment here...
yes..stroudtom wrote:Will the intune store a log if it is not married to the vehicle?mikel wrote:can you record a log then post it here?
Tom
Tried the PID restore and still showing 96 deg. Odd also the data viewer only shows external PIDS:AFR, Analog 1 and Batt Volts.sohfast94 wrote:mmmmm seems odd. MAke sure the tool is fully updated and then once you're done with all that go to scan tool - datalogging - configure - restore default pids
- 1B3HB68FX8D784489_01.log
- (89.78 KiB) Downloaded 162 times
Update your dataviewer
https://www.dropbox.com/s/35fpvbqo5guaz ... 7.exe?dl=0
It'll show up fine then.
Thanks Brian, the PIDS look fine with that update. Does this mean the Intune has issues displaying these values in the realtime log mode?sohfast94 wrote:Update your dataviewer![]()
