2015 Eco Boost Dead peddle Info Thread.
Re: 2015 Eco Boost Dead peddle Info Thread.
Install the tune (any tune) and then plug it into your computer and there will be the back up and last tune files. Then put back to stock to wait for mike to make you a tune.
Ok here are the files. This is with the 93 tune. I also tried the 87 tune. Both had dead pedal right away. Thanks!
Couple of questions.
Is there a rough percentage of vehicles getting a dead pedal? Say, out of 10 tuned, 1 has the issue. From what I'm gathering here, most of the vehicles with issues are the 3.5 with a few 2.7s.
Also, is there a way to disable the start-stop for the 2.7 without actually having to tune the vehicle?
Lastly, I'm tracking that the last update for the inTune is FORD_TUNES-1t02eb.
Thanks for the help.
DiabloMatt
sorry guys i was gone all last week. let me sort through all these and reply to them.
DiabloMatt
ksrracer wrote:So is this issue corrected via custom tune from you guys? Wanting to purchase an I2 hut want to know it will work lol.
yes... we can fix the problem with a custom tune. we are working on a update that will make them not break in the first place though.
hxrly wrote:Couple of questions.
these numbers i dont know. for what its worth i have been applyinh custom tunes to every person that has an issue and so far i have fixed about 30. we sold a HELL OF A LOT more than 30 lol.
i think you can do it through the dash but you have to turn it off all the time. the diablo tool will let you disable it entirely.
yes that is the latest.
Lfatty.....here is a 87 and a 93 tune you can use to fix your issues. they are at bottom of post.
juangorena wrote:Matt, everything has been working pretty good everything works , truck feel powerful , in the 93custom perf tune i feel like a little over boost , @ WOT and turbo indicator goes up and down (oscillation) on the 91 perf tune this oscillation dissapears , but i had a check engine lamp on , with a erratic turbo behavior , attached is the pic of the PCM Code, i have onin the 93 tune a heavy carbon deposit on the exhaust tip like fuel mixture too rich , and of course gas consumption is much much higher , it is possible to get a revised 93 perf tune to try ? , Does any modification in the custom tune like correct tire size or move speed limiter setting may affect ?
Guys as always thank you for your support , i think you´re getting closer to a very nice ending with this issue , is just fine tune what is missing , thank you again
Omar
can you get me a log of it doing this please...
Goose your 87 tune and 93 tune are attached at the bottom as well. these will fix your problem
adam81 wrote:I have a 2015 3.5L Ecoboost. I'm using the Diablosport inTune 1000. I updated the tool last week and get a dead pedal immediately. I'm attaching my lack backup. Can I have a custom tune please? Also, once you post it, do I simply save the file to the tool and then tune as usual? I'm new to this. Thank you.
adam81, your tunes are attached below to fix the issue.
- adam 93.frg
- (145.6 KiB) Downloaded 273 times
- adam 87.frg
- (145.65 KiB) Downloaded 279 times
- Goose 93.frg
- (145.59 KiB) Downloaded 270 times
- Goose 87.frg
- (145.69 KiB) Downloaded 222 times
- lfatty 93.frg
- (146.98 KiB) Downloaded 222 times
- lfatty 87.frg
- (146.86 KiB) Downloaded 291 times
Thanks DiabloMatt!
I'll try it when I get home from work & report back.
Thanks for the tunes Matt! Loaded the 87 and the truck runs good now. So far the pedal is still working after 10-15 key cycles.
DiabloMatt
lfatty wrote:Thanks for the tunes Matt! Loaded the 87 and the truck runs good now. So far the pedal is still working after 10-15 key cycles.
Goose wrote:Thanks DiabloMatt!
good deal guys
DiabloMatt wrote:lfatty wrote:Thanks for the tunes Matt! Loaded the 87 and the truck runs good now. So far the pedal is still working after 10-15 key cycles.
good deal guys
Not sure what I'm doing wrong here. I drag & dropped the tunes after downloading them to my PC.
I go to the tool & go to Advance Tune, however the Install Custom Tune is greyed out.
Any help would be greatly appreciated.
Thanks!
** EDIT: quick search & saw I was putting the custom tune in the Tune Folder instead of just dropping it in the main Folder
Tune installed & hoping for the best.
I opened the tunes folder for the device on my computer and copied them there. A few moments later the device buzzed and said they were installed.
Thanks for the answers Matt. I tried to modify the stock tune just to disable the start/stop, but couldn't find option. I then decided to tune it with the 91 tune and got the dead pedal right away. I'm attaching my last written file. I'm still trying to figure out how to disable the start/stop.
- PCM_BNPMBC7_LastTuneWritten.frg
- (174.61 KiB) Downloaded 247 times
here is my last written tune matt can you make me a tune thanks.
- info.xml
- (3.85 KiB) Downloaded 290 times
He'll need the backup file.joic0205 wrote:here is my last written tune matt can you make me a tune thanks.
DiabloMatt
hry bud we dont have a known fix for the 2.7 but i do have somthing to try. can you tell me what tool you are using and i'll try and get you a test filehxrly wrote:Thanks for the answers Matt. I tried to modify the stock tune just to disable the start/stop, but couldn't find option. I then decided to tune it with the 91 tune and got the dead pedal right away. I'm attaching my last written file. I'm still trying to figure out how to disable the start/stop.
Matt I have the intune tool. Thanks.DiabloMatt wrote:hry bud we dont have a known fix for the 2.7 but i do have somthing to try. can you tell me what tool you are using and i'll try and get you a test filehxrly wrote:Thanks for the answers Matt. I tried to modify the stock tune just to disable the start/stop, but couldn't find option. I then decided to tune it with the 91 tune and got the dead pedal right away. I'm attaching my last written file. I'm still trying to figure out how to disable the start/stop.
