U7170 hardware upgrade program in place!
RE: 2000 F250 SD...U7170...
Yes, that tool will need the $99 hardware upgrade to take the latest updates.
Thanks, I have the number to the RMA desk, will contact customer to determine if he wants to have the devise updated.
aaronpatton
Re: U7170 hardware upgrade program in place!
Can't I just download the upgrade program to my U7170? Why should I have to even pay for an upgrade in the programing? I thought I bought it with the correct programming.
aaronpatton
Will this upgrade programming increase my throttle response?
Is this upgrade still available? I just bought a 2002 ford 7.3 and it came with this unit. Is there a way to see if the previous owner did the upgrade?
Late to the party. Is this still available?? Are you answering questions in this forum anymore??
yes, this is available.
Do I need to install stock program back in truck before shipping. To avoid an extra $50 fee?mikel wrote:yes, this is available.
DiabloMatt
yes return the vehicle to stock firstkevinx wrote:Do I need to install stock program back in truck before shipping. To avoid an extra $50 fee?mikel wrote:yes, this is available.
I just started using my Predator tuner again on my Excursion and I get a PATS key disable. Will the $99 upgrade fix this. I do not remember this from the past but it has been a while since I used it last.
go to the modify tune menu and enable PATS then load the tune, that should resolve it.Grumpyjoe wrote:I just started using my Predator tuner again on my Excursion and I get a PATS key disable. Will the $99 upgrade fix this. I do not remember this from the past but it has been a while since I used it last.
You make it so easy. Thank You.
hubertandrew85
Is this this available for upgrade, i would love to have my predator upgraded
