efans?
Mattman84
efans?
Post by Mattman84 »
Is there any way i can check my tune to make sure the fans are activated on pin 42 or what degree the kick on/off? I'm on my second tune and they still are not coming on. The ac trigger works but not through the pcm. I have ls1 fans and a 3 relay harness
2000 5.3 silverado
u7198
RE: efans?
I have Johan looking at it again now.
Did you say it does come on with the A/C switch?
Mattman84
Post by Mattman84 »
yeah, when i turn ac on one fan comes on. The other never comes on even when up to the 180*.
OK, he should have it figured out today.
sickREDsierra
Post by sickREDsierra »
is your harness a nelson type harness or a homemade triple relay?
2007 Sierra, 370 C.I. , Custom CompCam, ProEdge 3600 converter, 4.11's with eaton LSD, Foose 20's, DynoTune Nitrous, Patriot CNC'd heads
Mattman84
Post by Mattman84 »
I bought the harness from DLH2006 on PT.net
Sent a new tune today..lemme know how it works.
Mattman84
Post by Mattman84 »
Where would i find the custom tune on my predator? All i see is 93/87 performance and factory tune
Yeah, you are not loading it correctly
What revision is on this tool?
Mattman84
Post by Mattman84 »
Its 2.13, I'm gonna reload it again this evening and see if I've over looked something. THANKS for the help
Return to “Predator GM Gas”
