Knock sensor voltage PID and DataViewer
AlexIV
Post by AlexIV »
I can select knock sensor voltage at the Intune and record it. But I never saw the option to see that pid at DataV. Might be I just missed that ?
Its important for me as sometimes I saw voltage 4.99 V at idle at one or at two banks. Some times zero and zero with the same fuel and weather in tank. I can not understand why knocks are at idle. It should not be like so.
So wanted to see the logs after drive but I didn't found it via DV.
Thanks in advance
Re: Knock sensor voltage PID and DataViewer
post the log...
AlexIV
Post by AlexIV »
mikel wrote:post the log...
here you are
well, it is not in that log, try the restore default PID option in the logging menu and try it again.
AlexIV
Post by AlexIV »
mikel wrote:well, it is not in that log, try the restore default PID option in the logging menu and try it again.
Ok, I will post it later, thanks !
