Updating Intune I-1000
only_1
Post by only_1 »
I bought a used Intune I-1000 and was trying to update it. After a number of tries the drive shows up when plugged in, but as having an error. It asks if I want to scan the drive and fix the errors. Then, if I wait, another popup will ask what I want to do with the cd portion. If I select run the intune icon it keeps going back to the registration website. As it gets there I get a popup window with a red "x".
What am I doing wrong?
Thanks for your help!
Re: Updating Intune I-1000
sounds like it needs ot be registered before it can be updated, post a copy of the info.xml file from the intune drive please.
only_1
Post by only_1 »
The info is one of the only .xml files I see. Hopefully its the correct one.
info.xml
(2.46 KiB) Downloaded 476 times
only_1
Post by only_1 »
I did try this on my laptop, which is running Windows 7 rather than the 10 that my desktop has. It did not make a difference. The computers are not able to load the drivers from the tuner. I don't get any kind of application window for this tuner on either computer.
only_1
Post by only_1 »
I may not even need this to be updated. I am going to use it on a 2007 Chevrolet Tahoe. The programmer has version 1r02r in it. I don't know what the difference is between that and the 1r02s. If its only to cover newer models and no changes were made for the older vehicles I can go with it as is.
Thanks for the help on this.
