2013 silverado Ltz z71 settings questions
Turtdogg
Post by Turtdogg »
What are the best settings for throttle response on takeoff? So far I've installed the diablo tune and am running 93 octane, turned off the torque management, and disabled the afm. I still feel like I need to adjust something for the throttle response from a dead standstill to takeoff. Any advice?
gregory
Re: 2013 silverado Ltz z71 settings questions
Post by gregory »
You may want to put a couple hundred miles on the tune first, it will change as computer learns and adjust to new program. :drivingbad:
yeah, Every time you install a tune, all of the learned items like idle, airflow, fueling/fuel trims, emissions readiness tests, etc. all get erased/reset... It takes days/150+ miles to be put on for everything to be relearned by the ECM/TCM and settle back in again before you'd be able to do a data log.
and there is no throttle parameter on that 2013 truck.. that parameter is only available on 2014 and newer vehicles/ECM's..
