vehicle not supported 2010 challenger r/t
darkspark
Post by darkspark »
I plug in the intune i2 and did the updater. it said that updates have been moved to my device and that it needs to be on the disclaimer page, but I don't see that it is doing any updates (it did flash something really quick then went back to the disclaimer page) and when I plug it in to my car it says the vehicle is not supported and it needs an update. my car was just updated from dodge with a cpm update for shooting issues.
bore the update I had a predator on it but now it is tell me the roll back to a older cal. id.
will this iTunes i2 work with my car?
if I do a roll back what will that do to my car as for the update will it undo the update?
Re: vehicle not supported 2010 challenger r/t
the i2 should download the update for you, connect it to a pc and let the updater run and click check now and then go back to the vehicle and it shouyld update the cal then let you tune it.
if not please post the info.xml file from the i2 drive here.
darkspark
Post by darkspark »
it still is not working, and I tried to copy the info.xml and it will not copy.
this is all it will do info.xml
and it has this file showing 68052005ad.drg
is this updating I left it plugged in for over an hour last night and it didn't change.
also I am using a macbook pro, I don't know if that matters.
its the Mac ;)
eject the drive, then it will import the file and should work fine.
darkspark
Post by darkspark »
I ejected the drive but it still says that my car is not supported
darkspark
Post by darkspark »
mikel wrote:the i2 should download the update for you, connect it to a pc and let the updater run and click check now and then go back to the vehicle and it shouyld update the cal then let you tune it.
I tried it in the car again and it still says it in not supported, I have used this on this car before then I took it in for the airbag recall, they did tell me they did a cpm update but that they don't know what was on it.
here is my info log.
<tool_info>
<registration sn="14U7Z5H8GZ" status="0" tool_oem="DIABLO_D" updates="0"/>
<applications count="5">
<application name="vehicle" rev="2r01h"/>
<application name="updater" rev="missing"/>
<application name="gui" rev="2r01e"/>
<application name="installer" rev="2r01c"/>
<application name="logger" rev="2r01a"/>
</applications>
<databases dbnames="2r00" dtc="2r01a" vin="2r01g" gui="2r01c">
<database mfr="DCX" tune="2r01c" pid="2r01cc"/>
<database mfr="FORD" pid="2r01cf"/>
<database mfr="GM" pid="2r01ba"/>
</databases>
<last-connected vin="2B3CJ5DT4AH278751" mfr="DCX" calid="68052005AF"/>
<last-connected calid="05150626AAke3k0"/>
<licenses available="1" tuned="0"/>
<unsupported calid="68052005AF" vin="2B3CJ5DT4AH278751" oem="DCX"/>
<reg reg="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"/>
</tool_info>
mrjay70
Post by mrjay70 »
did you ever figure out what was going on? I just took my car in and they did a software flash to the PCM and now mine is doing the same stuff. I DID restore the car to stock before tacking it in also.
darkspark
Post by darkspark »
I talked to the dealer and he didn't even know what was on the update
