Let us share your build!
Re: Let us share your build!
2015 Ram 2500 Big Horn 6.4 Hemi (Black Edition): Zone Off-Road 5.5" Radius Arm Suspension, Anthem Off-Road Enforcer Wheels, Toyo Open Country R/T, ICI Innovative Creations Magnum RT, Amp Research, DiabloSport Trininity T1000 Tuner, HemiFever Custom Tuning
#ram #zoneoffroad #anthemoffroad #toyotires #icimagnum #foldacover #weathertech #ampresearch #diablosport #trinityt1000 #hemifevertuning
- image.jpeg (299.96 KiB) Viewed 644679 times
- chefred112
2005 Dodge Ram 392 Stroker
Predator U7137 with custom tune
Inertia Motorsports 392 stroker upgrade (5.7 base original stock block with 250+k miles)
- Molnar Crank and Rods
- CP bullet pistons
Custom ground 232/238 cam
Inertia BV heads
Pacesetter lt headers
Duel DMH cutouts to 5x11x22 Magnaflow muffler
87mm ported throttle body
Summit crank pulley
Ramhammer cai
Taurus Efan
Sharadon stage 2 tranny valve body
Edge 2800 torque converter
6.1 SRT hemi fuel injectors
Caltracs on a 4/6 drop
I'ved used my Predator since the 1st day it was released to our Rams (05/06)...has been great for me since i 1st started modding the original 5.7
I haven't dynoed the stroker but if i had to guess, it is about 500hp or more. I'ved dynoed 390hp on a bad tune (at the time) on the 5.7 with a 214/218 cam (with the same mods used above except stroker, tb and injector compnents)
https://www.youtube.com/watch?v=PFls_d6ckLY
- CP bullet pistons
Inertia BV heads
Summit crank pulley
Ramhammer cai
Taurus Efan
-Fast Freddie-
05 Hemi QCSB
392 - 232/238 cam /heads/lt's/true duals/dual e-cutouts/cai/efan/3.92 gears/2600 stall verter/180 tstat/cat deletes
old 5.7- 214/218 cam/heads/lt's/true duals/dual e-cutouts/cai/efan/4.56 gears/2800 stall verter/180 tstat/cat deletes
05 Hemi QCSB
Bobjersey1
Looking for a nice custom gauge layout for my 2002 corvette c5 convertable. Any help would be greatly appreciated. Thanks! Bob
P.S. A little confused on what I would like/need. Also how to lay it out. Thanks!
2013 charger Arrington throttle body cat back Arrington CAI long tube headers T1000 kenne bell on the way
- image.jpeg (562.06 KiB) Viewed 641900 times
ajwalk2008
what year range on the taurus efan? what fan controller did you use?chefred112 wrote:2005 Dodge Ram 392 Stroker
- CP bullet pistons
Inertia BV heads
Summit crank pulley
Ramhammer cai
Taurus Efan
2013 Ram, mods in my sig
- 100_2297.JPG (1.22 MiB) Viewed 636967 times
- 100_2214.JPG (1.05 MiB) Viewed 637683 times
- 01011621.JPG (3.74 MiB) Viewed 637683 times
2013 Ram 1500 Express Hemi, Lakeland Cap, Bedrug, 20% Window Tint, Anzo LED Taillights, Bilstein 5100's all around fronts set at 1.4", Fuel Maverick 20x9 +1 Wheels, 305/55/20 Dura Trac's, MGP Caliper Covers, DiabloSport i2/Hemi Tune, Mufflex bolt on muffler
2014 RAM 1500 5.7 HEMI Laramie
Engine:
S&B CAI
UPR oil catch can
Magnaflow 18" muffler + J-pipe and 5" tips by Mufflex.
Suspension:
6" BDS lift kit(2.5" coilovers by Fox)
Spohn arms and adjustable Panhard bar
Hellwig adjustable rear sway bar
UCA by ReadyLift
Lower joints by Mevotech
Lights:
Grill and 30" LED bar by Rigid Industries
Diode Dynamics Switchback LED boards
Headlight upgrade with Morimoto bi-xenon lenses
Axles:
Gear Swap to 4.56
RMS 4.56 Rear gears
Auburn HP differential
MAG Hytec differential cover
G2 4.56 front gears
Exterior:
Bushwacker fender flares
20x12 XD wheels / 37x12.50R20 Nitto Terra Grappler G2
20x12 Fuel Vapor / 37x13.50R20 Nitto EXO Grappler
Hadley Horns H02009A
Engine:
S&B CAI
UPR oil catch can
Suspension:
UCA by ReadyLift
Lights:
Axles:
Gear Swap to 4.56
RMS 4.56 Rear gears
G2 4.56 front gears
Exterior:
- 3419eces-960.jpg (172.99 KiB) Viewed 634530 times
PSD QWIK FIX
Early 99 F250 SD Lariat extended cab 4WD 7.3L Turbo Diesel. Currently running the DiabloSport 85HP tune. To check out more pics and details on my full build check out my WheelWell page - https://wheelwell.com/profile/58023cd48 ... 11/garage/
dollybud48
2014 Mustang GT 302 with a 6 speed, Sterling Silver with saddle interior.
MODS to date in order of installation:
-Roush cold air intake
-Airaid 1 inch throttle body spacer
-Magnaflow outlaw mufflers
-Barton short throw shifter
-Diablosport i2 tuner
-Using Octane 93 race tune
-1&1/2 inch rear wheel spacers
-1/4 inch front wheel spacers
-black out rear quarter windows
- 8 bolt Strut Tower Brace
- 7 inch antenna
- 7 inch antenna
- IMG_1180.jpg (40.46 KiB) Viewed 631109 times
6.2lsierra
2016 GMC Sierra SLT All terrain dbl cab
Intune - S&B intake - Magnaflow exhaust - ground force 2-4 drop - and when tuning for the trans comes it will have a 5star tune
- IMG_0784.JPG (2.12 MiB) Viewed 630381 times
- IMG_0785.JPG (2.59 MiB) Viewed 630381 times
2016 GMC Sierra 6.2L SLT All Terrain
Intune - S&B Intake - Magnaflow - GroundForce 2-4 - Soon To Be 5Star Tuned
Love my Challenger R/T Classic. Diablo and Procharger Tune, 8PSI boost and all kinds of good stuff.
- 20160703_120418.jpg (4.82 MiB) Viewed 628783 times
Chris Ayers
2010 Procharged Dodge Challenger R/T Classic
Hurst pistol grip short throw shifter.
BBK Shorties
FLowmaster super 44 catback
BBK Shorties
motherPerf
2016 Ram Big Horn 5.7, with a Mothers Performance Products Spartan Turbo Kit, Intune2 and PCM
https://www.youtube.com/watch?v=NTAgICxuojY
2009 Charger SE 5.7L
2009 Police 5.7 VVT
K&N CAI and 180 Tstat
Diablosport Trinity
Canned Cai 93 Octane
1/8 [email protected]
1/4 [email protected]
Best was 1/8 8.96@81
1/4 14.05 @99.96
After Diablotoona
Custom tune
THANK YOU Yohan!!!!!!!!!!!!!!!!!!!
Both runs @ sea level Amb temp 65ish
Diablosport Trinity
1/4 14.05 @99.96
After Diablotoona
Custom tune
Well Mike I have been having a little trouble with my unit but I have been able to modify the parameters like cooling , the most important . But I still need some tech help . I have a 2012 Challenger SRT-8 with a five speed Auto , my modified cold air intake is from down below, I put on a set of Flowtech headers with off road mid pipes last week along with a new set of BF Goodrich Comp two rubber. My car is fast but not fast enough . So I hope someone can help me with this tuning . I live up around Ocala so I can make the trip to Sanford or wherever you guys are at. ttyl bye. as you can see I'm not a computer guy I posted the same pic three times ?
More 2012 SRT-8
- IMG_1244.JPG (2.13 MiB) Viewed 750383 times
- IMG_1255.JPG (2.16 MiB) Viewed 750383 times
