Add pid for data logging?
Hi Guys,
I want to add the PID's for the o2 sensors when doing some data logging but as soon as I'm trying to add a PID from the list the logging doesn't work and no logs are saved or visible in the Intune. The only way I'm able to log is to go with the factory default options which doesn't include the 02 sensors. Any advice on how to set the Intune up to log the o2 sensors?
I have a 2006 Jeep GC SRT8
/Andreas
/Andreas
Re: Add pid for data logging?
i1000 or i2010?
please post the info.xml file from the tool.
It's the i2010. I have to borrow a PC to pull the info.xml-file though. I only own MAC's and the Intune doesn't like that.
I found the info.xml I pulled when I first used the Intune in April and I haven't updated it since. Does that help?
you can access the i2 drive on a mac, even update it if needed...
Yes I managed to pull the latest info.xml (see attached file) but updating on a Mac is not possible. It was the same when I bought it, had to borrow a PC to do the update.
Anyways... Looking forward to help regarding adding PID's to the data logging.
Best Regards,
Andreas
Best Regards,
Andreas
I would definitely suggest updating it here, what happens when you try to do it on the Mac?
I updated it today (on a PC) but I still cannot add PID's to the logging. See attached image for how the Intune looks after I tried to add a new PID.
This is what happened earlier when I tried to update through my MAC: https://dl.dropboxusercontent.com/u/1063567/intune.mov I had a chat with one of your support guys at the time but we could never solve it so I just borrowed a PC.
when it shows that screen with no data, will it still record a log?
No. I get the question if I want to save the log but nothing is saved on the drive.
Hello again,
Any suggestions on how to get the custom PID's working?
Any update on the custom PID not working on the i2010?
I need to do some data logging to send to my tuner and the last time I tried I couldn't add PID's
2015 Ram 1500 5.7L w/HF 91 tune
mattechperf
I'm having a similar issue with my I2.
I'd really like to see a solution to this as well.
should be some updates this week that will resolve this.
