Data Log Issue
LS3Sedan
Data Log Issue
Post by LS3Sedan »
I am trying to do some data logging, but every time that I try to view, none of the PIDs are showing. It only gives me three analog inputs, Analog 1 Analog 2 and Batt. V
No idea whats going on here.....any insights as to why I can't seem to view the raw data from the file in the app?
Re: Data Log Issue
are you seeing PIDs on the intune when recording in the vehicle?
Using the default list?
LS3Sedan
Re: Data Log Issue
Post by LS3Sedan »
Yes, they show fine on the tool when doing the data log. But when I go to view on the computer nothing comes through.
Re: Data Log Issue
can you post one of the logs here?
LS3Sedan
Re: Data Log Issue
Post by LS3Sedan »
I can do that when I get home from work today....on another note, with the GM truck tunes is the Diablo Tune good for 91 octane or just 93? I'm sure it's been asked a million other places but got lazy and didn't want to search.
Thanks for the help.
Re: Data Log Issue
on the trucks Diablo tune is for premium fuel, 91 octane minimum.
LS3Sedan
Re: Data Log Issue
Post by LS3Sedan »
Here is a log that I ran today. Sorry it took me a while.....was traveling.
Also, seems like my fuel trim is trying to lean it out way too much.....it's showing long term at idle @-30 on both banks, also alcohol ratio way off.....pulling through that at 70%. I'm getting the alcohol ratio reset at the dealer, any other thoughts on these two issues?
Only things done to the truck, 2010 Chevy Avalanche, are intake and exhaust.
Re: Data Log Issue
LS3Sedan wrote:Here is a log that I ran today. Sorry it took me a while.....was traveling.
all th epids are there for me, are you using current DV from website?
LS3Sedan
Re: Data Log Issue
Post by LS3Sedan »
Yes I even uninstalled and re-downloaded to see if that would correct the issue but none of the PID's are view able for some reason.
