Different tunes question
Mr.X
Post by Mr.X »
Hi !
I just got my intune i2 for my Denali 2011 with the 6.2.
I was checking the different tunes and I was just wondering, is there any difference between the 93 tune on the easy tune and the Diablo tune in the advance tune option?
Also if I choose the Diablo tune in the advance tune and I modify the available parameters the changes that I made will be applied to the Diablo tune when I apply the tune?
Since I live in Texas and I am able to change the fan settings do you guys have any temperature setting do you recommend to apply to the fans?
Thank in advance !
Re: Different tunes question
you want to install tunes from the Advanced Mode menu... there's a bug in Easy Mode that they haven't fixed yet..
so go through Advanced Mode to install tunes.. Diablo Tune is the 91/93 octane tune for trucks..
yes, if you select Diablo Tune, then modify it and install it, the changes you made are applied to the Diablo Tune when you install it.
you can not change fan temps - you can only change the amount of power that the fans run at.. that's how all 2007+ GM vehicles are.. and the fan power is already adjusted and set to run at higher power than stock in the preset tunes... but yes you can adjust the power more if you want.
