Fan control adjustment not working on 2016 C7 Z06
Fan control adjustment not working on 2016 C7 Z06.
Select temp range, hit continue, tool goes back to fan control page.
Ideas?
Ideas?
Re: Fan control adjustment not working on 2016 C7 Z06
it wont let you select the individual temp cells?
When you select the temp cell and tap continue it returns the the primary fan control screen.
How do you adjust the % (speed) the fan runs in each temp cell?
you should be able to select a temp and then adjust up or down to set the % of fan power for that temp cell.
I will post a video of the display on the tool when trying to adjust the fan % later.
Michael Faggiano
Hi guys I have the same problem ! No fan control adj. on my 2016 Corvette Z51..
Last edited by Michael Faggiano on Tue Sep 06, 2016 4:31 pm, edited 1 time in total.
the dealer cant see anything, we'll have a fix for the missing fan params shortly.
Michael Faggiano
Ok Mike Thanks !
The support at Diablo has been great !
Installed latest update today.
Fan control parameter is still not functional on 2016 Corvette C7 ZO6!
Any solutions?
Any solutions?
There was a test build with this fix today, I need to confirm it was OK in testing then I will post it tomorrow.
please restore the stock tune then load htis update to the i2 drive and then when you reload the fan params will work properly.
Will test it today and let you know if the update works.
Fan parameters still not functional in 2t02vt and calibration causes the throttle to go into limp mode.
2t02vh only problem was fan parameters. Throttle was OK.
Back to 2r02v release until there is a fix.
Stock calibration file attached if you want to test internal.
can you email me and give me a little more detail as to what happened?
zhill <at> powertech . com
