I have a 06 2500HD LLY 4X4 CrewCab LT.
Took my truck into the dealer to get somethings worked on. New glow plugs, steering shaft, transfer case output seal. I took my 120hp tune out the night before and put it back to stock. When i got my truck back, i put the 120hp tune back in. When i hit the gas pedal the throttle stuck wide open. I thought WTF!!! I thought maybe floormate got under pedal. Well it didn't. Fired it up again and hit the pedal throttle stuck wide open. So i put stock tune back in and it was fine. Well i went out tonight to put 120hp tune in again. Hit throttle and it stuck wide open. Put 85hp tune did the samething. I thought well let me try 65hp tune. Did it again throttle sticking open. So i put it back to stock and everything works fine. Wondering if something is wrong with my tuner. I bought the tuner brand new when i bought my truck back in 2006.
__________________
Problems with Predator
RE: Problems with Predator
restore, update...
Turbobuick
I put it back to stock. So all i need to do is update right....
Yes sir.
Turbobuick
Cool Thanks!!! Looks like some are having problems with the 9r12. Is there a different version i should update to. I bought this about 3 or 4 years ago and never updated it.
use 9r08, sending it now.
Turbobuick
Re: RE: Problems with Predator
Thanks Mike!! Now i need to find my USB stuff i bought from you guys..mikel wrote:use 9r08, sending it now.
Re: Problems with Predator
Hello, new comer here. I'm experiencing the same problems with my 2006 LLY ccsb. How is this resolved ? Almost took out my stereo shop today...
nixsolutwxh
расцветки жидких обоев
Приветствую Вас друзья!
Есть такой интересный сайт для заказа жидких обоев SILK PLASTER или так называемой шёлковой штукатурки.
1)жидкие обои минск- SILK PLASTER - это обои из экологичных материалов, шелкового волокна и хлопка, созданные по мировому стандарту.
2)жидкие обои каталог фото- SILK PLASTER - это экологически чистые жидкие обои на основе шелкового волокна и хлопка, которые созданы по высоким мировым стандартам качества!
3)где купить жидкие обои- Жидкие обои SILK PLASTER отвечают абсолютно всем европейским требования по защите окружающей среды и безопасности для здоровья человека.
3)купить жидкие обои в витебске- Обои SILK PLASTER способны выполнять роль дополнительной звуко- и теплоизоляции в помещении.
4)жидкие обои silk plaster- SILK PLASTER - это шелковые обои, разработанные по новейшим технологиям. Это экологически чистый отделочный материал нового поколения, который позволяет создать гладкое бесшовное покрытие, скрывающее неровности стен.
5)нанесение жидких обоев в минске- Они без проблем выдерживают различные колебания влажности и перепады температуры воздуха, а также абсолютно не подвержены выгоранию на солнце. Не маловажным моментом является и то, что жидкие обои абсолютно не впитывают посторонних запахов (при этом и сами не пахнут после нанесения).
Нам будет приятно видеть у нас на вебресурсе НАЖМИТЕ ССЫЛКУ
От всей души Вам всех благ!
шелковые обои фото
видео как наносить жидкие обои
как наносить жидкие обои на гипсокартон
покраска жидких обоев
куплю обои жидкие
как наносят жидкие обои
нанесение жидких обоев форт
калькулятор жидких обоев престиж
silk plaster мастер цвета
жидкие обои
жидкие обои мастер силк
жидкие обои на стену
инструкция для форт 513
декор штукатурка
как нанести жидкие обои
каким слоем наносить жидкие обои
как наносить жидкие обои на углы
жидкие обои купить минск фото
шелковая штукатурка как наносить
штукатурка силк пластер
жидких обоев их удобно наносить
как рассчитать необходимое количество жидких обоев
как нанести рисунок на жидкие обои видео
штукатурка декоративная цена
жидкие обои фото дизайн
жидкие обои silk цена
silk plaster фото
сколько стоит нанести жидкие обои
отделка стен жидкими обоями
калькулятор расчета обоев по площади
жидкие обои инструкция
декоративная штукатурка silk plaster
краска для жидких обоев
жидкие обои минск
как покрыть стены декоративной штукатуркой
жидкие обои силк пластер купить
silk plaster жидкие обои видео
обои минск каталог
наносят ли жидкие обои потолок
жидкие обои дизайн интерьера фото
рассчитать количество жидких обоев на комнату
можно ли наносить жидкие обои ванной
расчетный калькулятор для жидких обоев
обои для квартиры каталог
каталог декоративной штукатурки
рб продажа жидкие обои
калькулятор расчета обоев на комнату
арт дизайн
состав жидких обоев
как наносить жидкие обои видео
шелковые обои фото
куплю обои жидкие
жидкие обои
декор штукатурка
silk plaster фото
жидкие обои минск
обои минск каталог
арт дизайн
состав жидких обоев
- nixsolutuuc
Привет друзья!
Предлагаем Вашему вниманию замечательный сайт для заказа жидких обоев SILK PLASTER или так называемой шёлковой штукатурки.
Нам будет приятно видеть у нас на сайте НАЖМИТЕ ССЫЛКУ
шелковое покрытие стен
жидкие обои как их наносить на стену
интернет магазин обои купить
жидкие обои форт 513 инструкция
расчет обоев онлайн
zidkie oboi
жидкие обои техника нанесения
жидкие обои фото силк пластер цена
обои в комнату
жидкие обои форт
штукатурка цена в минске
silkplaster премиум 805 фото
шёлковые обои
купить шелковую штукатурку
обои или декоративная штукатурка
купить жидкие обои в минске недорого
арт дизайн
жидкие обои силк пластер шоу рум
жидкие обои арт декор
шелковая декоративная штукатурка цена
silkplaster
дом жидких обоев каталог
купить силк пластер
отзывы о жидких обоях силк пластер
жидкие обои интерьер
калькулятор количества обоев
как наносить жидкие обои в ванную
купить грунтовку под жидкие обои
расчет обоев на комнату калькулятор
распродажа остатков обоев
каталоги обоев
виды жидких обоев
фотографии обоев
как наносить жидкие обои силк пластер на стены видео официальный сайт
жидкие обои с блестками
декоративные обои фото
жидкие обои на штукатурку
можно ли наносить жидкие обои на потолок
шелковая штукатурка силк пластер отзывы
silk plaster распродажа
обои каталог в минске
арт дизайн что это
фото жидкие обои
жидкие обои в интерьере прихожей фото
сколько хранятся разведенные жидкие обои
жидкие обои стоимость
расчет обоев онлайн
zidkie oboi
обои в комнату
жидкие обои форт
шёлковые обои
арт дизайн
silkplaster
купить силк пластер
каталоги обоев
виды жидких обоев
фотографии обоев
арт дизайн что это
фото жидкие обои
