Reduced torque management, when?
sickREDsierra
Post by sickREDsierra »
the converter def makes a big difference in taking off, but after that , TM still takes over whenever you shift at WOT....
my converter gets me out of the hole a lot quicker/harder. i also removed TM though.
2007 Sierra, 370 C.I. , Custom CompCam, ProEdge 3600 converter, 4.11's with eaton LSD, Foose 20's, DynoTune Nitrous, Patriot CNC'd heads
radzer0 wrote:Mike, U guys got any idea what the weak point is? If its the TQ Convertor i have no problem getting a high end aftermarket to fix that issue :P
The stock tranny is actually weaker than the converter....
I have smoked through 1 4L60 already, but my stock converter is fine and dandy...
sickREDsierra
exactly! you should have had a 65e in the camaro, but either way, the 60e is weak in a truck!!
what brand TC do you run? yank, tci, vig,....
The Ls1 cars all had 4L60s...no 65s. Lame.
I still run the stock converter right now...
sickREDsierra
oh, learn something new everyday. i am leaning towards the new 6l80e..... i think it would be worth swapping in mine, if the bolt pattern is the same. comes in the new escalades/denali's behind the 6.2l 405hp motor.
sickREDsierra
and i know you like my new mods!!! :lol: :lol:
Yeah, me wants a 6L80 as well.
They do bolt up, but there is some programming required.
Our new GM guy has a patch to allow the use of the 6l80 in non stock applications, should have it ready soon.
sickREDsierra
THATS WHAT I READ, THAT THERE WASNT ANY WAY TO PROGRAM THE pcm FOR THE EXTRA GEARS IN THE 6L80, BUT SOON AS ITS A REASONABLE NON-DIFFICULT SWAP, I AM ALL ABOUT IT.
radzer0
Post by radzer0 »
I would think the 6L80 is stronger than the 4L60.
Correct?
