AFM delete in 2010 Camaro
6.2streetboy
Quick question about the trinity..I have a 2010 l99 camaro ss and I want the AFM disabled. Will the preloaded tunes in the trinity do that or is a custom tune required?
Re: AFM delete in 2010 Camaro
you would modify the preset canned tune during installing it and disable the DOD, then continue installing the preset tune after you disable that setting, and it will install the preset tune with DOD disabled..
6.2streetboy
Ok thanks..So I would not have to use my pc for any of that correct?
no, that is done on the trinity itself when you are installing the preset tunes into the car..
you will need to use your Windows PC first though, before tuning your car.. because you need to update the Trinity to all of the latest updates first..
then you can connect it to your car and select/install tunes..
