Override installed test applications?
adfurgerson
Post by adfurgerson »
Update over wifi and get this screen,Override installed test applications? if I select no at bottom I get Updater Failed to Download: Peer certificate cannot be authenticated with given CA certificate. Am scared to select yes to override! Any advice?
Re: Override installed test applications?
something is not allowing your tool to validate the certificate.
Is this a normal home wifi connection, or a shared hot spot, etc?
JimH
Post by JimH »
Let your tool stay connected to the internet for a couple minutes and try again. The tool has to sync its internal clock up with internet clocks for https connections to the server. It should only take a minute or two.
adfurgerson
mikel wrote:something is not allowing your tool to validate the certificate.
Hotspotted off my phone. What might happen if I chose "yes" when prompted about the override?
adfurgerson
JimH wrote:Let your tool stay connected to the internet for a couple minutes and try again. The tool has to sync its internal clock up with internet clocks for https connections to the server. It should only take a minute or two.
Thanks, I'll try that the next time I'm able to work with it.
