Hello: I just recently re-acquired my 2006 Dodge 3500 with the 5.9 Cummins in it from a friend that had it for a few years and had the PCM replaced during that time. The Predator U7131 has the old V.9r02 file in it and will connect to the truck but says I have a calibration ID problem. The Cal ID is 35325553AW and the tool says the last tune written was the original backup. Can you guys help me out? I can't seem to find the old page that had the files for the Predator.
Thanks in advance
U7131 update needed
Re: U7131 update needed
try this update
- u7131-9r07.crom
- (1.85 MiB) Downloaded 1353 times
Sabretooth
Worked like a charm, thank you for the excellent customer service yet again
Sabretooth
Hello again: I have a question about the top speed limiter adjustment, is it still enabled on 9r07 and if so, where is it hiding?
Jeff
Jeff
if it is available its under the modify tune menu.
Im not following you here...wemkayanna wrote:This had another update sometime back in April this year.
Since this board is almost dead anyway, why not bump this again to help those that still own the original 2 Discs version of the game?
