Power differance, how to get it back 2016 F150 3.5L
Good morning, I have 2016 f150 3.5Leco, I just purchased your I2020 and was looking at the dyno charts from the last Gen 09-14 and was wondering why the older trucks make 80TQ more and 40hp more to the ground. I Finally found a dyno chart for the new ones ( only the 2.7 is on your tuner page) and realized the 2.7L makes just as much power with your programmer. Is there a tune to get the same power as the last gen trucks and why did the power gains go down. Thanks.
Re: Power differance, how to get it back 2016 F150 3.5L
the 16+ models actually make more power than the 11-14 models, I am not sure what you are seeing.
2.7 is quite a bit less than any 3.5
These are the only 2 dyno charts i can find as well as the 2.7L, if you have a more up to date one id like to see it. thanks
Can I please get a response on this matter, Id like to know what the real dyno numbers are. Thanks
Im not really following your question, what is it you feel is incorrect here?
What is the correct dyno for the 2015-16 3.5L ecoboost? The dyno charts above show the 3.5L to make almost the same power as the 2.7L while the dyno chart I posted for the 11-14 shows considerable more power for the older 3.5L.
2.7L dyno- 397TQ 315HP
Advertised power gain 40HP 70TQ
15-16 3.5L dyno - 405TQ 334HP
Advertised power gain HP 70HP 100TQ
11-14 3.5L dyno 486TQ 378HP
Advertised power gain 90HP 90TQ
DiabloMatt
the power gains are less on the 15+ trucks cause it is a completly different PCM and they are MUCH more picky on what you do with them. to ultimatly we were not able to get as much out of them safly as the 11-14 trucks. hope this helps some.
Thank you sir, that answers my question.
