pcm calibration
Brantina
pcm calibration
Post by Brantina »
i have a 2013 dodge challenger that i bought with 12,000 miles and now has 38,000 and i havent took to the dealership since i do most of my own mechanic work. i bought the itune 1000 dcx and tried writing a tune but it comes up as pcm may need updated and when click cancel it says vehicle not support. i connected the tuner to the computer and it doesnt download anything from when i opened the tuner and downloaded the first pc updates to it.
i received the tuner on feb 13, updated feb 13.
my car is also a 3.6l also.
Re: pcm calibration
please post the info.xml file from the intune drive.
bmwylliejr
Re: pcm calibration
Post by bmwylliejr »
I'm having the same issue. I just bought mine last week and finally got around to installing it. Here's my file
<?xml version="1.0"?>
-<tool_info>
<main svn="6604" sw_rev="1r03n" full_version="InTune-1r03n 09/23/2013 05:20:39 PM"/>
<registration status="1" sn="J243TD3-4"/>
<cal_id CM1="68349260AA" PCM="68171301AH"/>
<restore bc="0" vin="2C3CCAAG1DH599289" id="0"/>
<system_db vin="1r01g" dtc="1r01a" info="1r01b"/>
<db pid="1r01b" tune="1r01v" mfr="DCX"/>
<db pid="1r01b" mfr="FORD"/>
<db pid="1r01a" mfr="GM"/>
<license tuned="0" avail="1"/>
<unsupported vin="2C3CCAAG1DH599289" oem="DCX" calid="68171301AH"/>
<updates count="2"/>
<oem tool_oem="DIABLODCX"/>
</tool_info>
Re: pcm calibration
can you please attach the actual file?
bmwylliejr
Re: pcm calibration
Here you go.
Re: pcm calibration
please run the updater again now and it will download the file you need.
antoniofish
Re: pcm calibration
Post by antoniofish »
Hi! I'm having the same issue. What do I do?
Re: pcm calibration
post the info.xml file please.
antoniofish
Re: pcm calibration
Here's the file for 2013 dodge challenger
Re: pcm calibration
antoniofish wrote:Here's the file for 2013 dodge challenger
have you rtun the updater to let it download the file?
djpiezo
Re: pcm calibration
Post by djpiezo »
I'm experiencing the same problems as well.
I have the diablo tune(93 Octane) installed but I want to try the 91 octane tune but it prompts me
that I need a calibration update Before I Can Install it
I even tried to run the diablosport intune upsate but there is no update for my tune
Re: pcm calibration
the device needs to be updated then it should be fine.
djpiezo
Re: pcm calibration
Post by djpiezo »
i plugged it back in to the computer and there is no update.
if possible can u provide a link for the update
Re: pcm calibration
the updater said no updates available?
djpiezo
Re: pcm calibration
Post by djpiezo »
yes there is no update
