custom tune ?
custom tune ?
I just purchased T-1000 for my 05 gto . so I just changed cam. headers.removed cats. cold air intake. the car does not want to idle very well and wants to stall. how do I go about getting a tune for it.. is there any way to give some one cam specs and other information and get something close to get this thing running better so I can drive it around and get some data ?
Re: custom tune ?
increase the idle by +500rpm
Re: custom tune ?
check our dealer locator for a GM CMR tuner in your area.
Re: custom tune ?
I was reading something about emailing diablo and they would be able to send me a custom tune. is that not how this works ?
Re: custom tune ?
how do I do that ?06MonteSS wrote:increase the idle by +500rpm
Re: custom tune ?
no.. diablosport does not do custom tuning.. you need to find a diablosport dealer/tuner to purchase custom tuning.. use the dealer locator to find any around your area - http://www.diablosport.com/dealer-locator/
I do custom tuning for GM's, but I do not do medium/large cams like you have via email tuning.. if your car won't stay running with the cam installed, I can't help you... so you'll need to search for another tuner using the dealer locator...
Re: custom tune ?
select the tune you want to install.. select Modify.. go to Idle, and increase it.. then exit back out and install the tune.GTO wrote:how do I do that ?06MonteSS wrote:increase the idle by +500rpm
Full Trinity user manual: http://www.diablosport.com/content/uplo ... manual.pdf
Re: custom tune ?
ok thanks06MonteSS wrote:select the tune you want to install.. select Modify.. go to Idle, and increase it.. then exit back out and install the tune.GTO wrote:how do I do that ?06MonteSS wrote:increase the idle by +500rpm
