Tune not available for this calibration
saleen032
Post by saleen032 »
I have a 2007 Dodge Magnum that had the PCM flash updated. I did return the tune back to stock before the flash was done. Now I am trying to upload the tune again and keep getting an error saying to update. I completed the update and I am still not able to tune the car. XML file attached below. Any suggestions?
Scott
info.xml
(3.56 KiB) Downloaded 559 times
JimH
Re: Tune not available for this calibration
Post by JimH »
Please try running the updater again now. You should be all set.
saleen032
Post by saleen032 »
I tried to run the updater like you suggested, but it keeps telling me the intune is up to date.
are you running the ignition software?
I just checked and it is downloading the file.
saleen032
Post by saleen032 »
I ran the updater and checked for updates and it said I was up to date. I will connect it again tonight and leave it hooked up and see what happens. It never appeared to download a file.
saleen032
Post by saleen032 »
mikel wrote:are you running the ignition software?
Im sorry. What do you mean by the ignition software?
saleen032
Post by saleen032 »
I have an i1000, not the newer i2 unit. OS io have the standard updater software.
install the igntion software here:
http://fusionupdate.com/ignition/powert ... taller.exe
then connect pc and let it update the device.
