I've got the intune I2 for my 2005 300c Hemi, it doesn't have the MDS enable/disable option, is it available for this?
Also does anyone know if you can access the MDS enable/disable for a 2006 Jeep Grand Cherokee Hemi aswell? Thanks Nick
2005 Chrysler 300c MDS disable
Re: 2005 Chrysler 300c MDS disable
it cn be disabled on any HEMI, are you looking in the modify parameter menu under advanced tune?
Thanks for the reply, It only offers "tune select" & "quick adjust" when I select advanced tune? In quick adjust it just offers Tire size, transmission & traction control.
Still not got MDS disable option on the intune i2???
Do I need an update or why isn't it available? any ideas??......
you dont see the modify parameters button lit up in the advanced menu after installing a tune?
Thanks for the reply, it just comes up with Tune select or quick adjust when I select advanced tune
Still not got the MDS delete option in the intune, whose the best person to speak to about a possible update? Or look into why it's not working?
after you select diablo tunes, and pick the tune you want, you should see 'apply tune' or 'modify tune' options presented, modify tune is where you'll find the MDS option.
