U7194 tuning help
goblin_tinker
U7194 tuning help
Post by goblin_tinker »
U7194
Hardware - Univ_rev2
Version - 9r01
07 Silverado NBS WT
4.8 v8
bone stock
Using Philips 66 91 octane
Tune installed Diablo Performance
with WOT Spark set at -10% all ranges per MikeL to accomidate 91 octane.
I installed the tune a couple weeks ago and have been working through Lews tutorial on loging and adjustment. Drove a bit over 100 miles and took a couple logsand ran them throught dslogredux and it says adjust injector slope -3%. Make adjustment and another 60 miles couple more logsand redux says adjust -5%. OK now at a total of -8%. Another 60 miles and a coupe logs later and redux says adjust -6% witch would be -14%??
One of the posts in lews tut sugests that it might not be good to adjust down that low? Also in the last log the ltft's were stuck at 6.25% for the first few seconds then bank 1 stays at 6.25% and bank 2 stays stuck at 7.03%
I just wanted to get some feedback on adjusting the injector slope that far and the stuck ltft on the last log? Anything else I might be missing or should check?
EDIT
Yess I took 3 logs and averaged the results
U7194 has a short log limit - 1Min 16 Sec log
Only Log -
air fuel ratio
commanded throttle position
engine speed
long term fuel trim bank 1 and 2
oxygen sensor voltage bank 1 sensor 1 and bank 2 sensor 1
spark advance
total knock spark retard
Last edited by goblin_tinker on Wed Apr 02, 2008 11:51 am, edited 1 time in total.
ches111
Post by ches111 »
Goblin,
Are you taking an average for those readings?
The averages should NOT be all over the place like that...
How long were you logging for?
What parameters did you log?
Can you post your log to this thread to let people take a look at it?
no, somethings not right here... something's up with your truck and/or predator... the ltft's should not be all over the place like that and staying positive...
HOWEVER, there's currently an issue with the 7194's where they are not actually making/saving the adjustments... it may look like it - cuz you can make the adjustments and then re-install the tune to your vehicle, but it doesn't actually write those changes/adjustments to your ECM.
johan
Post by johan »
We did the 9r02 update for this, as there where issues with parameters not applying. Update to 9r02 and re log it.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
a-HA!! Thanks Johan!!
so you need to update your predator like Johan says... then make sure you reset everything back to the default settings of 0, and re-log...
06MonteSS wrote:a-HA!! Thanks Johan!!
Cmon man, I posted an announcement about this the other day...dont you read the stickies?!?!
LOL.
goblin_tinker
Alright Thanks Guys! Ive got that update downloading right now. Ill start over start over and see how that works out. Let you know in a couple days.
Thanks again for all your help.
goblin_tinker
Sorry Mike I remember seeing something about the 8r10 not applying dod changes but as I had 9r01 i asumed that it didnt apply to me? Oh well thatll teach me to asume anything. Anyway got the updat now off to reprogram :lol:
goblin_tinker wrote:Sorry Mike I remember seeing something about the 8r10 not applying dod changes but as I had 9r01 i asumed that it didnt apply to me? Oh well thatll teach me to asume anything. Anyway got the updat now off to reprogram :lol:
No biggie...I was just messin with Lewis...
LOL.
ohhhh, why I oughtta....!!!
yeah, like he said Mike - your "half-a-sticky" says the issue applies to the 8r10 revision, yet mentions nothing about previous revisions being affected as well...
Mike, please feel free to take a look at my stickies at the top of the GM forums as a prime example to follow on how to be clear and concise in your provided information and how they should be written, so as to allow people to actually understand the full gamut of information you are trying to disseminate to the masses.
Hmmm... maybe you guys should freelance someone to write documentation for you... :roll:
:lol: :lol: aaahahahahaha...
goblin_tinker
ok now I have a problem with the new revision 9r02. It tells me that my vehicle is not supported??? I tried serveral times. first time went as far as setting automatic trans then got the message now get the message after selecting performance tune option.
Ok, do me a favor, with the tool plugged in, make sure the key is all the way on, and if it says unsupported again, turn the key off then on, without unplugging the tool.
If it still says it, try unplugging the tool then plug it right back in, without turning the key off, and try again.
If this still does not work, let me know please.
goblin_tinker
Ok I got the same results each time.
fuses pulled radio, amp and info.
verified onstar disabled
doors closed no fans or other accesories on
plug in tool
turn key all the way on
performance tune
unsupported
key off then on
performance tune
unsupported
unplug plug in
performance tune
unsupported
johan
Post by johan »
Could you post your vin or e-mail it to me?
Diablosport INC
goblin_tinker
Ok Vin = 1gcec14c37e600953
