Intune says tune writing failed
I have an Intune that I got with a 99 corvette I bought and after updating the firmware I tried to reprogram the car with the diablo tune in case of any updates. The intune goes thru the whole saving backup and then says it wasn't able to write the tune and then prompts you to restore the saved tune which I did, so now the car starts and shuts off about 3 seconds later, the lights on the climate control panel stay on all the time and even the dome lights quit working when I open the door! Any thoughts on this? I now have a 3000lb paperweight.
Re: Intune says tune writing failed
did you try updating the device before using it?
disconnect the battery for a minute and drain voltage then it should clear up the issue.
