New DSLogRedux Update Available...
NEW UPDATE AVAILABLE FOR DOWNLOAD!!
http://www.dslogredux.com
Added new tab with functionality to provide AFR info for WOT in both lower and upper rpm ranges, as well as provide recommended adjustments to PE fueling in both lower and upper rpm ranges.
Also now includes the tutorials/information from my stickies on here, regarding logging, making adjustments, and how to copy your tune file from your vehicle.
This information has been compiled into a PDF file and is available from the Help menu in the application - as well as from the Help page on the website.
sickREDsierra
RE: New DSLogRedux Update Available...
Post by sickREDsierra »
clap clap clap!!! amazing Lew, and everyone that had a hand in this!
get a sticky on this, please. ..... this should take care of 60% of the questions posed on this board.
great job guys!! :mrgreen:
2007 Sierra, 370 C.I. , Custom CompCam, ProEdge 3600 converter, 4.11's with eaton LSD, Foose 20's, DynoTune Nitrous, Patriot CNC'd heads
yup, there already is a sticky for this app up top - "DSLogRedux Info Available Here!!" I posted the update info in there as well...
thanks sickRED...
but besides myself, BIG thanks go to Frank (GrumpyAeroGuy) for being the actual app programming whiz!!!!
I just provide the necessary info/data/requirements, but he's the one that makes it all actually work!
Goatluver
Post by Goatluver »
Thanks again!
05 GTO - M6
U7191 ver 9r02
08 - Avalanche LTZ
i1000 ver 1r04g
CANUCKPREDATOR
Post by CANUCKPREDATOR »
You guys are freakin' awesome!!!! Now go have a beer on me. You deserve it. :D
Grumpy_Aero_Guy
Post by Grumpy_Aero_Guy »
too late.... LOL... already started on that
maybe next weekend
(Thank you sir ! )
Last edited by Grumpy_Aero_Guy on Sat Apr 05, 2008 5:18 pm, edited 1 time in total.
DSLogRedux.com
hahaha... thanks man!!
New update available!
if you use our app, please consider registering for the email notices (and donating :) ), so if we forget to post here, or stop posting here, about new releases, at least YOU will still know there was an update and can go download the latest version!
Thanks!
CANUCKPREDATOR
With this modification to the program, would it make sense to have some other RPM ranges. Maybe user input cruise RPM range (Hi/Lo) For example, I just bought a trailer and when I'm towing in D with the 4.10 gears, I'm around 3000 rpm at highway speeds. Would it make sense for me to log and make adjustments for MY RPM range for MY situation?
hmmm... that may be opening up a whoooolllllle 'nuther can-o-worms...
k, but your normal everyday driving, doesn't include hauling the trailer all the time....
you'd want to log and make adjustments based on your normal everyday driving... without the trailer...
also, when doing your log, you don't HAVE to be at highway speeds of 65-75 mph...
you drive steady and do your log for one of the target RPM ranges... no matter what mph you're at... if you hit 1800-2400 rpms at only 40 or 50 mph, then set your cruise control for 40 or 50mph and log away...
according to the diablo guys, it doesn't matter what speed you're at - if you can be in the rpm range at only 40 mph, then that's all you need to do - that's as fast as you need to go. It's the rpm range that's the important factor, not the vehicle speed.
CANUCKPREDATOR
I haven't logged anything with the trailer in tow yet, but I have noticed its VERY flat until the revs get over 27-2800. What I'm thinking, and correct me if I'm wrong, is that if I would log and make adjustments for when I do have the trailer on and then reset back to my current setup when I don't have the trailer. I know it means alot of screwing around, but if I can get the truck to run better in both situations, I'd be willing to do it. Since my steady state driving with trailer on is around the 3000 rpm mark, wouldn't it make sense then to have your tune for that RPM range?
CANUCKPREDATOR
bump
do a log with your normal steady driving without the trailer, see where your average ltft's are at...
do one with pulling the trailer, see where your normal ltft's are at...
you may find that they are the same or pretty damn close and not worth adjusting for...
email me the logs and I'll check'em out...
NEW ANNOUNCEMENT!
Now that the new 7192, 7193, 7195, and 7198 Predators (revs. 9rXX only) are being shipped, we can announce that DSLogRedux is already able to support these new log files.
Get the latest DSLogRedux version (6.1.1) from our site ( http://www.dslogredux.com ), and you'll be able to analyze your new log files!!
there are some certain parameters that these older vehicles' PCM's do not have and therefore cannot log (compared to newer vehicles ECM's), however, we have made changes in DSLogRedux that will detect this in a log file, and will prompt you with further information.
For info on the logging parameters for these predators, view the LOGGING section of the sticky located here: http://diablosport.com/index.php?name=P ... opic&t=917
johnc
Post by johnc »
WHERE IS MY DSLOGREDUX T-SHIRT!!!!!
johnc <at> diablosport.com
Return to “Predator GM Gas”
