Tire size, rev limit and transmission options not available?
Hi, I just purchased a Predator 2, downloaded the Ignition software, updated the tuner, and installed the 91 octane tune on my 2007 Dodge Charger RT. When I bring up the custom options, the menu is very limited. It does not have the tire size, rev limiter, transmission shift, etc options listed. Am I missing something? Thanks, Dave
Re: Tire size, rev limit and transmission options not availa
So I drove it this morning and can't tell any difference either. Not sure it took the program although it went through all of the motions.
2007 Dodge Charger RT 5.7
Predator 2 7301
SN 2010040802
Predator 2 7301
SN 2010040802
please update the device so we can get some reads and we'll sort it out.
mikel wrote:please update the device so we can get some reads and we'll sort it out.
Thanks! I brought it to work with me and just updated it.
It does appear that the tune is loading and working to some extent. It just isn’t giving me options to adjust the transmission, tire size, rev limit, etc.
we're looking into it.
Any idea on whether this is a common problem or if it will be resolved soon? I purchased this to calibrate the speedo for larger tires, firm up the transmission shift points, and remove the rev limiter, none of which are working. I've had this for a few weeks now and not sure what the time frame is that I can return it for a refund if it's not going to work. Thanks.mikel wrote:we're looking into it.
it is being addressed. Sorry for the delay.
mikel wrote:it is being addressed. Sorry for the delay.
Still no luck???
Is there an update? Thanksmikel wrote:it is being addressed. Sorry for the delay.
This is taking longer than Id like.
If you would prefer, please give us a call and we'll swap you out for a different device that will have all these features.
Please reference 347992 if you call in.
Will do. Thanksmikel wrote:This is taking longer than Id like.
It should be delivered to you today. USPS tracking number is 9114901496451088074861 Please let me know when the new one is on the way. Thanks.
