i3 Tranny and traction
Got a i3 tuner loaded up on my 17 Ram: Diablo tune, throttle @20%, rev limit and speed limiter set, and fan adjusted but there is no options for a tranny tune or traction control disable! Am I missing something here? how do I get those options? Other than that the truck is noticeably quicker!
Re: i3 Tranny and traction
is this a 6 or 8 speed?
17 Ram Night: 8 speed. Also is there no tow tune provided?
Did you update the device prior to tuning the first time?
Post the info.xml file from the i3 drive please.
Yes I updated it before installing. I will post when I get home tonight
Here you go.
Restore the stock tune to the vehicle please.
Then download this file and save it to the i3 drive, and let the device import it.
https://drive.google.com/open?id=144Anz ... z6AS94Ascr
Once its loaded, go to the truck and it will ask you to check for an update for the TCM, when that happens, dont run ignition, post the info file here or email it to me at mlitsch @ powerteq.com and I will get you the files you need to proceed.
Cool thanks. I will get it after work!
I uploaded that file and when it was done it said TCM update completed. When I plugged into my truck it said new calibration available for TCM. It then calibrated and asked for stock tune or Perf. Tran Tune I selected Perf. and it installed the Performance Tranny Tune and backed up original TCM tune! So I think we are good!! Definitely a big difference in shifts!!!! Thank you.
awesome, enjoy.
I Have the i3 for my Ram with the 6sp I have no trans options? I also have updated before using.
Thanks Marco
Thanks Marco
you should see shift points under the modify tune menu.
