Stabiltrak Light flashing 2015 Silverado
briggssilverado
Post by briggssilverado »
New here and to Diablosport products but I have a issue. Stabiltrak Light flashing when making left or right turn, I have a 2015 Silverado 1500 4x4 7.5" lift and 35" tires. I was using a Hypertech and wanted more features so I bought the I3 and now this light keeps flashing and my truck will bog down for a few seconds. Anyone else with this issue or know of a solution. I have tried reducing tire size on the I3 from 35" down to 33.50 without any changes to the light.
Re: Stabiltrak Light flashing 2015 Silverado
I could swear I have seen someone else post about this here and found it was an issue with the truck itself...
briggssilverado
It’s not the truck because if I return it to stock the light does not come on at all when driving the same roads.
wheel speed sensor problem...
briggssilverado
If I return my truck back to stock and remove the tune the light does not come on if I get my old Hypertech max energy the light does not come on but when I install the 87 tune from the I3 the light comes on. Definitely the tuner...
then need to set the tire size smaller until the light doesn't come on.. or have your dealer reprogram the ABS module to allow for a larger tire size...
there is nothing in the preset canned tunes that would affect that.. there is nothing in the tune for stabilitrak/traction control, those are ABS systems.. so after you change the tire size, if it triggers the stabilitrak, then it's because the tire size is too big and it's making the ABS module wig out..
briggssilverado
Any other suggestions? I took the tire size from 35” down to 32” and the light still comes on and speedometer was way off at this point. I return the stock tune and the light doesn’t flash on when turning. I really don’t want to give up on this thing just yet. Was really considering the T2 but this is making me hesitant.
briggssilverado
Alignment is good too...
briggssilverado
n
Last edited by briggssilverado on Wed Mar 21, 2018 1:46 pm, edited 1 time in total.
briggssilverado
It is hard to believe I am the only one with this issue. I just tried a Hypertech Max Energy 2.0 and guess what? NO LIGHTS FLASHING. It is nothing like the I3 but since the only responses I would get would basically blame it on my truck rather than trying to figure out what is the cause. I wasn't looking for custom tunes, I was looking for correcting tire size and speedometer, and turning off AFM.
briggssilverado wrote:It is hard to believe I am the only one with this issue. I just tried a Hypertech Max Energy 2.0 and guess what? NO LIGHTS FLASHING. It is nothing like the I3 but since the only responses I would get would basically blame it on my truck rather than trying to figure out what is the cause. I wasn't looking for custom tunes, I was looking for correcting tire size and speedometer, and turning off AFM.
I dont delete anything from this forum, if it was reported, it would be here...
isiddall
Post by isiddall »
maybe a stupid question, but if you take the corner much slower does it still do that? I know on my Sierra's it's pretty easy to break the tires loose with just too heavy a foot, which of course, puts on the TC light and bogs down the engine...
briggssilverado
yes it still comes on, tires were not even losing traction at all. There is an onramp to get on the interstate and it is almost a complete circle, this light stayed on the whole time until it straightened out. When I saw a prius on my ass I said thats enough of this crap! I resolved the issues with Hypertech 2.0 Max Energy, I am not sure how but after a lot of research I found this tuner corrected that issue.(yes I know it is not custom) I have no error codes and my tire size was adjusted properly and speedometer is now correct. Half the price and no issues I'll take it anyway of the week.
M_O1500
Post by M_O1500 »
Have you tried another tune see if the light still came on? I'm new to this tuner as well and just wanted to know my self. I'm using the 93 canned tune
