performance tests
This section of the forum is for discussion relating to the use of the T2 EX tuner/monitor on GM vehicles.
ncscfan
performance tests
Post by ncscfan »
not working getting error pids could not be read .recorded some logs but cant view in data viewer t2 9245
Re: performance tests
please provide your serial number and I will set up a fix.
ncscfan
Post by ncscfan »
201115173
ncscfan
Post by ncscfan »
Just checking to see if you got my serial number 201115173
they're gone man.. it's the weekend.. won't be back until Monday after 9am eastern time...
connect it to your Windows PC/laptop and run the Ignition Updater to update your T2 to all the latest updates/fixes.. and then try it again and see if things are good to go or not..
I have a T2 myself, and it works perfectly fine on my modded 2016 5.3 Suburban truck, modded 2014 Camaro 2SS/RS LS3, modded 2012 Sierra 5.3, just fine.. no issues... must be a Dodge issue.. get a faster/lighter vehicle.. LOL j/k hahahaha ;)
please update with ignition now and the performance test issue will be resolved.
ncscfan
Post by ncscfan »
Got it everything seems ok now thanks just got to take a test run later
Osbhphil
Post by Osbhphil »
Having the same issue as NCSFAN described with Performance Test. Do I just re-run installer on Ignition or does a fix have to be setup just for my s/n.
Osbhphil wrote:Having the same issue as NCSFAN described with Performance Test. Do I just re-run installer on Ignition or does a fix have to be setup just for my s/n.
please post your serial and I'll set it up.
Return to “T2 for GM”
