2016 ram 1500
2016 ram 1500
What quick adjust options should I have available on the 2016 ram 1500?
Re: 2016 ram 1500
tire size and traction control disable.
Re: 2016 ram 1500
All I have available is the tire size. I had traction disable until I updated to the 8 speed trans support on the T1. I recently upgraded to the T2 and it still is not available. Any ideas on how to fix it?
Re: 2016 ram 1500
Can you please post the info.xml file from the t2 drive so we can check it out?
Re: 2016 ram 1500
is this what you need? Sorry it took me a while to get this. I was at work all day. Thank you for all your help.
