Transferring data from I2 to T2
ducatidesmo
Post by ducatidesmo »
Just traded up from an I2 to a Trinity 2 Rep told me to just pull everything out of the "tunes" directory, and I'm assuming that I place them in the "tunes" directory of the Trinity 2. Is there anything more that needs to be done?
shooterjgs
Re: Transferring data from I2 to T2
Post by shooterjgs »
I guess you just load them (custom tunes) off like when they were loaded on to the intune from you email... Looking into this also cause I'm getting ready to do the same as you and upgrade from the intune2 to the Trinity2... I think that's what was told to another forum member on another post... Hopefully a DS tech will answer.
if you are using a custom tune, you'd simply load that to the T2, but no need to transfer anything else.
ducatidesmo
I receive an error now. I pugged it in and went tune, stated that I had an unsupported powertrain module and that I needed an update. Would no longer update over wifi, so plugged it in, and then received the error as seen in the image (reads "Unsupported file for your calibration not found. Please contact techincal support")
ducatidesmo
More specifically, the error message that I receive is "There are control units in this vehicle that are currently not support. and Update may be required. Please plug into a PC and run..."
ducatidesmo
Info.xml added
copy this to the i2 drive and let the device import it then load the update to the vehicle then you may tune it.
ducatidesmo
Hey Mike,
Thanks for the cal file. after I got my replacement I was able to get everything updated and squared away... I have a problem now... The T2 loaded the stock tune back (which I'm assuming is standard procedure when loading a new calibration file) The problem is, I uploaded all my custom tunes into the T2 (got the notice that they were loaded successfully, on each tune) but... when I go to custom tunes, the only selection is "read backup"
Of course, they aren't in the Diablo tunes... What are my next steps? I've added the new Info.xml file if you needed it.
At this time, my Jeep is un-driveable, so looking for help as soon as possible. I left a message with your team, and also reached out to the tuner... I thought I would try this route as well.
post up the backup from the t2 and the custom tune you are trying to load and I will fix it.
ducatidesmo
Have them added.
Thank you for this. I wanted to make sure that This was ready to go for an event on Saturday and my Jeep is dead in the water.
Thanks again!
-Derrick
I see 2 different tunes there, which one do you need?
Return to “T2 for Dodge/Chrysler/Jeep/Ram”
