t2 not reading anything
v2performance
Post by v2performance »
just got pcm pkg with t2, first it kept resetting and crashing , i couldnt update it through the wireless so hooked it up to the pc and then i was able to update it after that i tried to on the car it wouldnt read anything and get stuck on turn key on screen and some times i get scrambled picture
Re: t2 not reading anything
can you please post the info.xml file from the T2 drive?
v2performance
sure this it
please update it one more time with ignition and post the new info file after the update.
v2performance
here
everything looks correct, can you try it again now to see if it is the same?
