i2 not working... please help
Mafia3140
Post by Mafia3140 »
i2 is not working right. Able to select "TUNE VEHICHLE" then on next screen it says make sure vehicle is run position and not on. After I click on continue it says PLEASE WAIT. at this point it does nothing else but stay on please wait. After fifteen minutes I disconnected it. I must add that the truck has a custom tune it in from the i2 and it only started this after an update from the IGNITION software. ALSO I'm unable to connect to my wifi. After I put in my password, it says please wait then after a short time it says session timed out.
Re: i2 not working... please help
save tgis to the i2 drive and let it import the file then try tuning again please.
Mafia3140
Post by Mafia3140 »
Thanks Mike, That solved all my problems. Great tech support.
danisrt8
Post by danisrt8 »
hi, i have a similar problem with the ignition updater because when i update my i2 for mi jeep srt8 6.1, a go to the tune vehicule, click on the advance tune and click in install standard tune and i select diablo tune and dont do anything, i cant install in my jeep. I attachment the info.xml. Please helppp
Return to “Ignition updater”
